06-13-2015 11:34 PM
06-25-2018 05:36 PM
Thanks, John
It appears some of the "blend modes" such as Bright or Contshtg are not available on the 6D (or Mark II). The rest of the article looks good, though. I'll try to apply some of hints in the article.
Dave
07-03-2018 04:58 PM
I'm following up with the results of trying both the Additive and Average summing methods for 3 exposure images taken with a 6D Mk II.
1. I tried Additive summing for 3 exposures and set the exposure level to -1 F-stop. I had an indoor closet for a background and took the first exposure centered, the second exposure to the left, and the third exposure to the right. The first image was a little under-exposed and the left and right exposures were barely visible. The background was exposed fairly well, though.
2. I tried Average summing for 3 exposures and set the exposure level to nominal (+/- 0 F-stops). These exposures were taken outside against a tree. The first exposure was pretty faint (under-exposed) but darker than the Additive method exposure. The left and right exposures were still under-exposed but much darker than before. The left exposure contained a branch of the tree in it. I guess I should have seen that coming, though... The background was still exposed fairly well,though.
3. I tried Additive summing for 3 exposures inside with a black poster background. Exposure was set to nominal. The first (center) exposure was much darker but still under-exposed. The left and right exposures were much more visible and only very slightly under-exposed. The background was epxosed fairly well.
4. I tried Average summing for 3 exposures with the same setup as step 3. The first exposure was more under-exposed and the left and right exposures were over-exposed. The background was exposed fairly well.
I appears the Additive summing method produced the best results of all the tests.
I've read several articles on this subject but nothing seems to indicate that kinds of results I'm getting.
Has someone had practical results in combining 3 exposures into one summary image? If so, I could really use some insight into an example or details on how you did it.
Thanks for any help.
