07-21-2018 08:37 AM
Dear all
I have a problem with batch-processing images from my recent trip. For some photos I had the camera-internal peripheral illumination + chromatic aberration correction turned on, while for others I have them turned off.
Is there a way to find out which have the said corrections and which have not, so that I can subsequently apply the corrections in Lightroom correctly to all my photos (and avoid applying it twice)?
thanks and best wishes
07-21-2018 09:11 AM
For a RAW image the camera doesn't modify the image; it applies a tag that Canon DPP can read to apply the corrections. Adobe softare can't read/apply the tag.
But when i have used Canon DPP and switched the corrections on/off an aeffect isn't always apparent because the lens may not have a significant issue that needs to be corrected.
I see this especially when using full-frame EF lenses on a crop sensor camera. The edges of the lens, where correction is needed more, are not being captured by the reduced field of view.
07-21-2018 08:50 AM
If you are processing RAW images in Lightroom then the in-camera settings don't matter. They are only read by Canon DPP.
07-21-2018 08:53 AM
07-21-2018 09:06 AM
Are you processing RAW or JPEG images?
https://forums.adobe.com/thread/2362401
07-21-2018 09:06 AM
07-21-2018 09:11 AM
07-21-2018 09:13 AM
07-21-2018 10:02 AM
Actually the answers are just partly correct. In the case of raw files, thumbnails that are automatically generated by your camera tells Lightroom how to generate a thumbnail and preview based upon that thumbnail, or jpg image. Lightrooms default settings will be applied later as the preview continues. So in a way the in camera settings do effect what LR is importing.
The good thing about Raw files is the greater latitude of adjustments that can be made. Not the fact they are influenced, or not, by the cameras settings. The mere fact that you can view a Raw file suggests it was modified.
07-21-2018 10:09 AM
Don't get me wrong, the Raw file itself is not altered in any way just what you get to see is.
07-21-2018 10:48 AM
@ebiggs1 wrote:Actually the answers are just partly correct. In the case of raw files, thumbnails that are automatically generated by your camera tells Lightroom how to generate a thumbnail and preview based upon that thumbnail, or jpg image. Lightrooms default settings will be applied later as the preview continues. So in a way the in camera settings do effect what LR is importing.
You seem to be saying that Lightroom will show you a JPEG thumbnail that incorporates settings - associated with the RAW file - that LR itself will ignore. I'm not surprised that the OP is confused by what he sees.
