MY EOS 30D works just fine until I put it on a tripod, then it won't take pictures. Any ideas?
jimocarroll
I have had my 30D for some time now, and it has worked flawlessly.  Today, I tried mounting it to a tripod to take some pictures.  It will not release the shutter.  If I press the shutter release button, the indicators in the viewfinder all light up as usual, but the shutter will not release.  If I activate the built in flash, pressing and holding the shutter release eventually causes the flash to blink as though in red-eye prevention mode, but the shutter will not release at all.  Pressing the * button results in the flash firing.
The tripod is a Manfrotto model, which I have also had for some time and am using for the first time.  The lens is a zoom tnat came with the camera.  The camera is mounted mechanically to the tripod using a quick-release adaptor, also a Manfrotto product.  The quick release adaptor has been on the cemera for some time, and it has operated flawlessly until I mounted it on the tripod today.
There are no electrical connections that I am aware of between the tripod and the camera, unless there's some hidden feature of which I am unaware.  I have no remote shutter release, but planned to use the timed shutter release setting.  Both the timed and normal modes work flawlessly when the camera is hand-held, both modes work flawlessly, but when the camera is on the tripod, it won't take a picture.  I am flummoxed by this.  Neither the camera manual nor the Manfrotto tripod manual are any help.
Any ideas?
Thanks.
Jim Carroll
Hi!
We just wanted to let you know that we don't recommend do-it-yourself repairs. So, if you’re experiencing a problem with your EOS 30D, it’s best to let a professional Canon Factory Service Center Technician do the work to keep you and your gear safe.
You can reach out to our friendly, U.S.-based support team at http://bitly.com/CanonSupport for some troubleshooting steps, and they can let you know the steps for service is necessary.
Thanks!
34 REPLIES 34
ebiggs1
It probably is not focusing.  Make sure you have it on the green square and the lens switch set to AF.  Try again.
EOS 1DX and many lenses.
jrhoffman75
If flash is blinking like that it sounds like it is too dark for camera to focus; thats the focus assist. Are you in a dark shooting situation?
Waddizzle
Yeah, alll of the above, and be sure to observe the MFD, minimum focusing distance, of your lens.
kvbarkley
What happens when you take the camera off the tripod, hold it just above and try to shoot?
Taken off the tripod, in exactly the same lighting situation and pointed at exactly the same subject the camera functions flawlessly.
Green square, lens set to AF, bright room lighting.  Off tripod, functions normally.  On tripod, will not release shutter and take a photo.  I'm still stumped.
The ambient iight is bright enough to take a picture without flash.  Again, when hand-held, functions exactly as it always has. On the tripod, it won't take a photo.
Long shot, do you have your eye on the viewfinder on the tripod? Try putting on the viewfinder cover.
could the weight of the lense when not being held make it loose contact maybe?
