01-26-2025 03:52 PM
I've had DSLRs in the past, but this is my first mirrorless camera and my first with a video recording capability (yes, my other cameras are VERY old!). Anyway, here's my question. I want to use a shoe-mounted boom mic for recording and listen through headphones while recording. I know there is no audio output on the camera, but are there boom mics with a monitor output? I've looked at several, and none of them have headphone outputs. Is there such a beast? Or is there another way to do it?
01-30-2025 04:03 AM
Yes. That one, or there are other models that have different connections and features too.
01-27-2025 08:41 AM
I found this one (Shure VP83F LensHopper) and found a used one on eBay. Hope this works.
01-27-2025 12:21 PM
To not be limited to the microphone itself, especially if it has to be used gear, you can also consider getting a Beachtek adapter. This is what you would use to connect a professional shotgun/boom microphone that has XLR output to the camera, and also the adapter would have a headphone output for you to at least monitor the signal coming from the microphone before it goes into the camera.
01-27-2025 01:04 PM
01-30-2025 04:03 AM
