05-05-2014 12:07 PM
Hello,
About a month ago i bougth Canon EOS 600 D with 18-55 mm and 55-250mm lens and everything goes fine i capture moon images and wildlife pictures as well.
But, now i'm facing some problem with it.
Recently i was trying to capture images with my Canon EOS 600 D and suddenly i noticed that the images are not sharp at all and the images show red and blue spot. I don't know what to do i'm just an ammature in this.
Please any one can help me with this problem.
05-05-2014 12:29 PM
That's chromatic aberration, it's a type of distortion that exists in all optics to some degree, but varies by the lens. In general, cheaper lenses will have more CA, especially something like the kit lenses. You'll notice it more in high contrast situations, like a bright white moon on a black background. You can fix it to some degree in post with programs like Lightroom or Photoshop.
05-05-2014 12:53 PM - edited 05-05-2014 12:57 PM
Like Skirball said, it's CA problem with the lens and also color noise from high ISO image.
The first image: low ISO (ISO100), lack of contrast (the moon is not bright, underexpose a bit). The second image, really really high ISO (ISO6400), high contrast (the moon is much brighter). The setting for 2nd image is recipe for color noise and CA. This is normal, there is nothing wrong with your equipment. Also when using high ISO, you will lose some detail in the image; thus it will look softer.
05-05-2014 12:29 PM
05-05-2014 12:32 PM
Sir,
but initially it was working fine i've captured images in the dark as well.
I'm constantly monitoring moon rotation day by day.
But suddenly this kind of thing happened. I didn't dropped it or do anything wrong
05-05-2014 01:02 PM
Thank you very much for your answer. Thank god there is notihing wrong with my equipment i'll try capturing photos tomorrow and get back here with the results. I'll definately know that the things you both por's said here gonna work for me.
Thanks a lot again
05-05-2014 01:07 PM
05-05-2014 01:13 PM
i'll try adjusting CA and ISO and get back here with the improved results
05-05-2014 01:25 PM
If you're taking shots of just the moon then the exposure value won't change all that much day to day. I recommend shooting in full manual, use the same settings that you used that gave you images you liked as a baseline. Low iso, nice middle aperture, and adjust shutter speed to fine tune the exposure. The next day you start at the same settings and adjust the shutter speed slightly if needed to account for a change in brightness. Good luck, have fun.
05-05-2014 01:30 PM
is dead pixel looks different from this
05-05-2014 01:43 PM
