08-13-2013 01:08 PM
I cannot set an F stop of 4.0 using my EOS 60D with my Canon EF 75-300mm 1:4-5.6 IS lens. I have tried changing the shutter speed and the ISO and I still cannot set an F stop of 4.0. Any recommendations? Thanks in advance.
08-14-2013 02:25 PM
You would need to contact Canon for repair options and prices. All we know at this point is that it's not correctly reporting it's focal length to the camera -- we don't know why. It should be serviceable.
You would need to tell them that the lens always reports 300mm as the focal length even when set to other focal lengths.
08-13-2013 01:37 PM
Depend on the focal lenght of your lens, if it's set at or near 300mm, you can only set the aperture to 5.6. It's the lens limit, not the camera. It's not a fixed aperture lens, so you cannot set F4 at all focal lenght.
08-13-2013 01:52 PM
Thank You, However, I cannot set the F stop to 4.0 even when the focal length is set to 75.
08-13-2013 05:53 PM
08-13-2013 05:59 PM
08-13-2013 06:10 PM - edited 08-13-2013 06:12 PM
what is the widest Aperture you can set @ 75mm? F5.6? Also look at the marking on the lens to make sure it is @ 75mm.
08-13-2013 06:14 PM
08-13-2013 06:43 PM
Are you, by chance, using a 1.4x teleconverter / extender -- or is the lens attached directly to the camera body with no other components involved?
A 1.4x converter will take 1 full stop away from you. That's normal if you're using a 1.4x.
08-13-2013 06:48 PM
08-13-2013 06:57 PM
