01-10-2017 09:22 AM
I have a EOS Rebel XT amd I was wondering if there is a way of directly transferring the photos directly to my iPhone 6.
Thanks
Lewis
01-10-2017 11:24 AM
You simply have to get a CF card reader with a lightning connector rather than one made for the SD card.
01-10-2017 09:31 AM
Not gonna be easy. You might try emailing them to yourself, to the iphone, after you transfer to your computer. At any rate your computer is going to be involved. But I use an android which uses a micro SD card so it is easy. But still involves my computer.
01-10-2017 09:42 AM
You need the camera connection kit.
01-10-2017 09:46 AM
I picked up an Apple SD/lightning card reader for my iPhone 6S on eBay for $10. It came from China, but is an Apple product and connected with no problems at all. Put in the SD card, plug it into the phone, and you'll get the import option popping right up. Transfer is fast and easy.
01-10-2017 11:22 AM
My Rebel XT takes a CF card not a SD card. Does that make a difference?
01-10-2017 11:24 AM
01-10-2017 11:25 AM
Sounds so **bleep** simple..... thanks. Will look intio getting it.
01-10-2017 12:10 PM
@StanNH wrote:You simply have to get a CF card reader with a lightning connector rather than one made for the SD card.
Every card reader I ever saw, except SD readers built into a laptop, accepted both SD and CF cards.
What's a "lightning connector"?
01-10-2017 12:12 PM
It is the end that goes into the iphone instead of a USB
01-10-2017 12:13 PM
