01-13-2015 01:06 PM
I am new to this and so far I love my camera. However shooting these games is sometimes difficult. How do I keep the background from being out of focus. Sometimes using the auto focus it catches someone's arm that closer than the intended subject and I miss the shot. How do I avoid that. Your help is appreciated. Thanks
01-13-2015 04:34 PM - edited 01-14-2015 01:49 PM
When you look through the viewfinder you'll see 9 boxes arranged in a pattern. These are the AF points. When using all points the camera checks all points and sees if there is something it can focus on at that point. It then decides what the subject is and focus on it. Sometimes it will jump back and forth between something in the foreground and background. But since the subject is typically in the foreground the camera is typically going to choose that over background noise. In your case, something is coming into the foreground and the camera is choosing that as the focus point since it's the closest. Best way to eliminate is to be cognizant of all AF points when shooting. If things are too dynamic to keep all 9 points free of non-subjects, then move to a single AF point:
If you want precise choice of the focus point then change it to only read the center point. There should be a button on the upper right that allow this. If you half press the shutter the camera will focus on whatever is at the center point. You can then recompose (if you want) and take the photo.
01-14-2015 10:30 AM - edited 01-14-2015 10:30 AM
Most likely cause is not enough light. Which means the apperture the camera is selecting to get the exposure right is too wide (smaller number). As that number goes down the depth-of-field, DOF, also get smaller. And that means less will be in focus.
Try selecting a higher ISO number. The T5i has an outstanding ISO range and you should be able to use 6400 easily.
Plus I would only use the center focus point for action shots like a BB game.
You do realize there is a limit to what the camera is capable of? Hopefully you are not out of it's ability.
01-14-2015 11:27 AM
01-14-2015 11:43 AM
01-15-2015 10:57 AM
You may want to try out "back button focus".
This moves the auto-focus activation to a button OTHER than the shutter button. It means that as you track a player on the court, if someone close temporarily gets in the way, the camera will NOT re-focus on that distracting subject. The camera will ONLY focus when you press the "back button". You use a technique with your finger on the shutter as always, but your thumb on the back-button. You activate the focus button with your thumb (or just hold it in) but as you spot someone about to get in your way, you RELEASE the back button so the camera continues to be able to shoot... but wont re-focus. As soon as whatever was in your way is back out of your way, you can press the back-button again to resume focus.
On your camera the 'back button" is the asterisk (*) button -- but you have to enable back-button focus for it to have an effect.
Go into Menu and navigate to Custom Fn. IV "Operation/Others" and scroll over to sub-option 6 which is "Shutter / AE Lock button".
You'll have 4 choices (0 through 3) and "0" is the default. But the key is knowing how to read Canon's notation on this screen. You'll see a partial description, a slash (/), and another partial description. Everything BEFORE the slash (/) will be performed by the front button (shutter button). Everything AFTER the slash will be performed by the back button (the asterisk button).
If, for example, you pick choice #1 "AE lock/AF" it means that if you half press the front button it will perform an AE lock and if you press the back-button it will activate AF. I would probably try #1 or #3 (#3 is identical to #1 except that it wont "lock" the AE after metering... it will meter continuously and since your subject is moving from area to area as you track them and the light may be changing, you probably want continuous metering (hence #3).
If you choose #1 then as soon as you half-press the shutter, it will lock metering and keep that exposure set ... if a subject moves to different lighting it will not update the metering UNLESS you release and half-press the shutter again. Using #3 it will just keep updating the metering as they move.
Back button focusing is popular among a lot of sports photographers but it isn't for everyone (some people hate it) and it does take some time to get used to the feel of it until it comes naturally to you. But once it does finally start to come naturally to you, you'll find you have a LOT more control because now you can indepently control focus vs. shooting (you don't have to force a re-focus (to a subject you didn't want to focus on) just to be able to shoot.)
VERY IMPORANT: If you DO try out back-button focus... don't forget you did that. Otherwise the next time you grab the camera and try to take a photo, you're going to think your AF system is broken when you press the shutter button and nothing focuses (yep... done that!)
01-15-2015 11:09 AM
01-15-2015 11:24 AM
Start with center point focus, in One Shot mode. You've learned about AF modes, and you've learned how to select and use your AF points. Two valuable skills that will have a positive impact on your photography. Once you've mastered those skills then worry about things like back button focus and whatnot.
01-16-2015 07:18 PM
01-17-2015 09:30 AM
"... lenses with wider apertures to let more light in, ..."
If the goal was 'more in focus' that suggestion won't help. The "wider" aperture will make less in focus as the DOF decreases.
The OP either needs to get the focus point more accurate or use a higher ISO to keep the lens aperture smaller (larger number=larger DOF).
