03-08-2015
10:46 PM
08:44 AM
How do you take a picture of the moon using a Canon EOS Rebel T5 DSLR camera with 18-55mm IS Lens?
Please can someone give me directions cause i have looked everywhere .?
02-26-2016 10:29 AM
Guys:
We *don't* know if a long lens is necessary. Ansel Adams did not use a telephoto for "Moon rise over Hernandez", after all. The OP has to tell us what kind of picture they are trying to take.
02-26-2016 11:39 AM
Ansel Adams was a master in the darkroom. Maybe more so, likely more so, than a photographer. After the correct exposure is obtained, I believe most of the magic is done in manipulation in a post editor. Just like Adams did for Moon rise over Hernandez.
02-26-2016 11:53 AM
The moon is about 1/2º from edge to edge (it has an elliptical orbit and it's distance from Earth varies by nearly 10% over the lunar month so it gets a tiny bit larger or smaller...but not by much.)
The shot I posted on the previous page (and I've taken numerous such shots through several different scopes) happens to be taken at roughly 1080mm... but then I cropped in just slightly (it's not much of a crop.)
I did the math and it turns out that at 1500mm lens using an APS-C sensor works out to about .6 degrees in the narrow direction and .9 in the wide direction. You need .5 to capture the moon. So a 1500mm would be a tight fit... but it would fit. I suppose you could turn the moon sideways during a quarter phase and get even closer.
Anything shorter and you'll just have more room. If you want a shot of "just" the moon then you'll be cropping in more aggressively with shorter focal length lenses.
If you want landscape in the foreground... that's fine... just be aware that depending on lighting conditions, the foreground may need a LONG exposure to get much revealsed... and that will blow out the moon.
One technique is to take advantage of the fact that wen the moon is near a 1st quarter phase all the way up to just one night before the actual night of the "full" moon the moon will rise BEFORE the sun sets. That means you can get into position just after sunset as the sky transitions through dusk to darkness and take the shot when the light of dusk is still providing foreground illumination. If you're planning to make a color image then often a rich blue sky is more attractive than a black sky anyway (and light pollution tends to just create a muddy sky that looks even worse.)
You can use tools such as the Photographer's Ephemeris (they have a website and an app) to calculate precisely where the moon will be located in your landscape on any given night. That way if you want the moon in your shot, you don't have to get lucky... you can figure out precisely where you need to stand and when you need to be standing there to get the composition you want.
02-26-2016 12:20 PM
I use the web site TimeAndDate dot com to find the moon.
02-27-2016 11:56 AM
@ebiggs1 wrote:Ansel Adams was a master in the darkroom. Maybe more so, likely more so, than a photographer. After the correct exposure is obtained, I believe most of the magic is done in manipulation in a post editor. Just like Adams did for Moon rise over Hernandez.
Ansel Adams, were he alive today, would likely be one of the world's foremost users of, and advocates for, Photoshop.
02-27-2016 06:06 PM
@kvbarkley wrote:Guys:
Also, Ansel Adams didn't even wait for night. Moonrise was shot during the day. He darkened the sky in the darkroom.
The story of the making of the photograph Moonrise, Hernandez , New Mexico is legendary. Ansel’s description in Examples: The Making of Forty Photographs is oft repeated, and quite dramatic. We have brought together several vignettes that put a little more perspective on what let up to the dramatic moment on a lonely highway at 4:05 PM (local time), October 31, 1941.
On that day in Hernandez, NM the sun wouldn't set until 5:09pm.
01-28-2021 02:15 PM
I know this is a reply to a very old thread but I ran across this wondering the same thing and thought some actual examples of moon pics w/ an 18-55mm lens would be useful. Hopefully this will be helpful for anyone else that comes across this in the future.
I used the f/11, ISO 100, 1/100 "looney 11" rule as suggested, and used a Canon EOS Rebel T7i with 18-55 lens at full zoom, no tripod (hand held), in JPG mode, and no post editing other than cropping the picture, so this is about as basic / point and shoot as you can get.
Original picture:
Same image, cropped to just the moon:
01-29-2021 10:34 AM
What most people don't realize, it it is daylight on the Moon. If it weren't you would not be able to see it. Anyway not as brightly as we know it. The fact that it is dark here has no bearing on the Moon but somehow people relate to that darkness here.
You need a bigger lens, my friend!
01-29-2021 07:36 PM
You can get some very nice moon photos with other items in the foreground for context with a short lens but for detailed photos of the moon itself, focal length is your friend. If you are using a shorter focal length lens like the 18-55 then try to compose a photo with interesting foreground items to tell a story.
These photos were shot with a Canon 1DX III using in order of photos: EF 800 f5.6 lens, EF 800 plus 1.4X, EF 800 plus 2X, and using a Celestron CPC 1100HD telescope as the camera lens (equivalent to a 2800MM f10 lens).
Rodger
01-29-2021 08:23 PM
You mean like this:
