How do I remove the battery from EOS Rebel T3i camera?
MelissaEverett
Help!  I figured out how to open the compartment and there seems to be a little release mechanism but I can't get it to stay open or actually release the battery.  Anyone know the trick?
5 REPLIES 5
Skirball
I've never used a T3i, but the battery latch is more or less the same.  You should just slide it to the side and the battery will pop out.  You can turn it over while holding it to the side to help it.
However, do you by chance have a generic battery you bought off a third party?  Many of them are sized incorrectly and get stuck.  If that's the case you need someone to hold the latch open while you use a good pair of needle nose and try to get purchase on that little plastic tab.  I had a couple like that for my old 450D.  I ended up wrapping dental floss around the batteries so I had something to pull up on.
Thanks, it worked.
annliningsmith
i can't even get the sliding opener to open the door, much less get it to stay open.
lisahansen
Hey Melissa,
Watch this video: https://www.youtube.com/watch?v=gLuyEpsueRQ
I hope this is helpful. Smiley Happy
Since this thread is 5 year sold I hope Melissa got the battery out by now!
