High speed r6 mark2 problem
longeye
H and H+ is grayed out not allowing to set fast shutter speed.
Note:  (red tab 1 -  duel pixel raw is disabled)
4 REPLIES 4
Waddizzle
Check your shutter mode.  If you have not already downloaded a copy of the full User Guide, then I recommend that you do so.  Use the link below.
https://www.usa.canon.com/support/p/eos-r6-mark-ii
"Fooling computers since 1972."
deebatman316
Also what batteries and lenses are you using. If you're using adapted EF lenses. Only certain EF lenses support H+ shooting mode on the EOS R series. Canon has the list of supported lenses in the manual. Also LP-E6NH batteries have to be used to allow H+ shooting to work. The use of older LP-E6 or LP-E6N won't allow H+ shooting.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF Trinity, EF 85mm F/1.8 USM
Retired Gear: EOS 40D, EF 50mm F/1.8 STM & EF 70-210mm F/4
Re H & H+ gray out problem.  Thanx for your reply.
Day 1 /OWNER:  New R6 Mk2 with Canon 100-500 with Canon supplied battery.
Still unsolved - but will download full user guide as suggested by Waddizzle to search further for answer.
I thought I’d already described the problem to you.  Check your shutter mode.
