09-04-2022 08:43 AM
Help! My Canon EOS 90D randomly freezes, the only way I can get the camera going again is to take the battery out and re insert. Anyone else have this problem? Or know what the issue is? It seems to be getting worse over time.
Thanks
Gee
09-04-2022 10:47 AM
You need to call Canon it needs service. 1 (800) 652-2666
09-04-2022 10:50 AM
Are you using any 3rd party items ie lens, speedlite or a battery. If so remove them and try it again. From the factory.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT, 600EX II-RT
09-04-2022 10:59 AM
How are you using the camera just before it locks up?
There are four possibilities.
You can test the first three yourself by using a different lens, battery, or memory card. A bad battery is probably the least likely cause. Try removing the memory card and lens, and see if it locks up.
09-04-2022 01:08 PM
Canon lens, Canon battery, Brand new memory card.
I thought the EOS 90D was supposed to be a good camera?! hmm
09-04-2022 01:10 PM
I'm in the UK - but will probably have to take it in - thanks
09-04-2022 01:11 PM
Are you using full size SD cards. Micro SD cards can cause the camera to lockup. Do you have another lens and battery to test.
-Demetrius
09-05-2022 10:49 AM
"I thought the EOS 90D was supposed to be a good camera?"
It is! 🙂 One of Canon's best, if not the best, crop sensor DSLR camera.
09-05-2022 10:51 AM
Full size memory card - thanks for your reply
09-05-2022 11:25 AM
GeeBabe any thing can fail at any time. It's just the way it is or maybe the luck of the draw. We hope it won't but it happens and that's why there are so many repair shops around town.
