12-21-2021 12:28 AM
Hi there. I am looking to connect my Canon m50 camera to my computer so I can live stream on Streamyard and/or Zoom.
For some reason my MacBook Pro computer won't connect to the camera. I see the screen below.
I have installed the Canon Web Utility Drive from the company's website. I also have restarted my computer.
Things I have tried:
None of these methods seemed to work.
Any help would be greatly appreciated! I can't figure out what to do.
This is the error I see:
12-21-2021 09:51 AM
You most definitely want to use a USB cable with the EOS Webcam Utility, not an HDMI. If you use an HDMI cable and a capture device, then any issues are most likely the fault of the capture device. Also, you do not want to connect both an HDMI and a USB cable at the same time.
https://www.usa.canon.com/internet/portal/us/home/support/self-help-center/eos-webcam-utility/
If you are getting that display, then the EOS Webcam Utility is not seeing your camera. You should also make sure that the app you are trying to use with the Webcam Utility is actually compatible with it. Canon has tested a number of apps, but they cannot test every app out there. Even then, there is no guarantee that a given app should or must work with the Webcam Utility.
Check your USB cable. Make sure that you are using a USB data cable, not a USB power/charging cable. One way to check is to see if your camera connects to the computer using the conventional EOS Utility app for downloading images from the camera.
You also need to make sure that no other app is trying to connect to the camera when you use the Webcam Utility, including the Canon EOS Utility for downloading images from the cameras. The camera can talk to only one app at a time, and it will not automatically switch on its own.
12-21-2021 09:53 AM
On the Mac, that includes Image Capture.
12-21-2021 10:00 AM
My money is on Monterey not liking the capture card.
What happens if you plug another source into the card?
~R5 C (1.0.9.1), ~R50v ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It
12-21-2021 10:15 AM
@shadowsports wrote:Greetings,
Good point. The EOS Webcam Utility is not listed as being compatible with Monterey at the link that I posted above.
12-21-2021 10:38 AM
@Waddizzle wrote:Make sure that you are using a USB data cable, not a USB power/charging cable.
Thanks so much for your reply. Wondering if this might be the main issue? The cable I was using might not be the right thing. Does this look sufficient? 😅
12-21-2021 10:39 AM
Hey, not quite sure what you mean. Make sure Image Capture is not active?
12-21-2021 10:40 AM
Not quite sure haha. I don't have anything else to plug into the card.
I bought this HDMI cord and capture card about a year and a half ago (before Canon had an Apple drive available). Maybe these are no longer needed? Thanks for the reply.
12-21-2021 10:41 AM
Oh godddddd. Whattttt? So I can't live stream because I'm on Monterey?! Surely there has to be a solution for this right? 😩 Is there anything I can do?
12-21-2021 12:11 PM
Yes, run image capture with the M50 attached with USB and set it to not do anything when it is plugged in.
