Grips on either side of Rebel digital body gotten sticky
diannekoz
I have a digital Rebel.  The grips on either side of the main body have gotten very sticky and a black almost tar like substance comes off on my hands when I hold it.  I cannot find a way to replace it.  Any suggestions on how to coat or cover it so it doesn’t come off on my hands, clothes, etc?  Anyone else have this problem?  Thanks!
16 REPLIES 16
Waddizzle
Which camera model do you have?  In my experience, the outside surfaces of the cameras are fairly durable under average usage conditions.
I have the 300 Digital.  There is a large grip on the right and a smaller grip on the left.  The black substance comes off on my hands and is really hard to get off.  It’s also very sticky.  I’m afraid I’ll get it on the lenses or dials.
Tronhard
VIP
VIP
I have had that phenomenon occur to me with a camera and some tools.  Basically it is a kind of degeneration of the plastic.  To clean it up, this is what worked for me: get Isopropyl alcohol (not methylated spirits, or anything else that will leave a reside) and, applying the alcohol to a rag (not directly onto the camera) apply some serious elbow grease and it should removed the degraded layer.  You will have to be patient and persistent.
cheers, TREVOR
Thanks!  I will definitely try that.  Where would I find the Isopropyl alcohol?  Someplace like Home Depot?
You can get it at a hardware store, or a drug store.   It's useful stuff to have around in general for all sorts of cleaning jobs that might involve petroleum-bases materials, residue after removing labels etc.
cheers, TREVOR
Rubbing alcohol is isopropyl. Your drugstore probably has 70% and 90%. Get the 90.
FloridaDrafter
I've had the same experience as Trevor, but with just an old camera. I was able to gently clean it off with 70% isopropyl alcohol. However, once rubber has started to degrade, you really can't stop it, so this is just a temporary solution. Your camera is very old, so it's no surprise that the grips are degrading, whether naturally or maybe something it's been exposed to. I read an article that explained that products like sunscreen, insect repellent, or even some perfumes, can cause rubber to degrade. Mine was never exposed to these products, but it was very old.
Newton
I have had many cameras much older than this, including a Canon SLR, and have never had a problem,  This is from about 2005 and is always in a camera bag when not in use, which is why it is strange.  I will try the Isopropyl alcohol and hope for the best.  Thanks!
Sometimes it just type of material used on a particular model. Canon had a similar problem with I believe it was the Rebel T4i.
If this is something you want for your grandchildren as a long term hobby you might want to check with Keh camera. They have Digital Rebel XT, which I think is one or two generations newer than yours for less than $50 rated excellent condition. They do have a Digital Rebel for sale; it is noted as surface sticky.
