01-02-2019 09:00 AM
01-02-2019 05:11 PM
If you think you selected something in error you can go into the menu ystem and select the option to reset camera to factory settings.
01-04-2019 11:50 AM - edited 01-04-2019 12:02 PM
I am not normally a fan of using the pop-up flash because the flash is too harsh, but I would go with what jrhoffman says, and/or call 1-800-652-2666 for a repair.
Another non-orthodox solution perhaps is buying previous generation 430-ex ii on the used market because the cost of repairing the pop-up flash might be more than buying a used speedlight assuming the repair cost is $150-$200.
01-05-2019 10:04 AM
It is possible the flash tube has burned out. You single option before calling Canon is to reset the camera in the menus under the tools tab.
02-12-2019 01:26 PM
I have the same problem and I made a video to show you guys. Unfortunaly I am outside of the us and cant refer to the support service right now.
