10-15-2016 08:37 AM
10-15-2016 11:23 AM
1. Line up the colored dots.
2. Insert the rear end of the lens into the opening.
3. Turn the lens clockwise until you hear it click.
10-15-2016 12:49 PM - edited 10-15-2016 12:50 PM
Do you mean you get an error message about the lens not communicating with the camera?
There are sevreral possibilities: 1. dirty contacts. carefully wipe contacts on lens and camera with a microfiber cloth. 2. sticky contacts. Gently push on the contacts in the camera body to be sure they travel freely. 3. failing conductor cables in lens. Lens will need repair/replacement depending on cost benefit comparison.
10-16-2016 09:57 AM
thanks for your response. I have tried the contact cleaning. I fear the latter "conductor cables". Will pursue a local shpo/dealer to determine. Thank you
