08-15-2023
11:07 AM
11:09 AM
I have a Canon R5 and R6. When I auto focus with my R6 and then switch to manual focus on any of my RF lenses, the focus remains what the autofocus was. On my R5, when i switch to MF, the focus is totally different. Can anyone help figure out what setting I might have changed on the R5 and how I can get it back to keeping the same focus setting from the auto focus when I move to manual focus? Thanks
08-15-2023 11:25 AM
You could try resetting camera and custom functions back to factory defaults.
08-15-2023 11:43 AM
I am not sure if these apply, but check these settings in the auto-focus menu. Also download the lens manual and see what it says about manual focus for your lens.
08-15-2023 05:07 PM - edited 08-15-2023 06:44 PM
Hello, David, and welcome to the Forum!
I can't figure out which setting might be messing with your switch from AF to MF, but I can confirm that it should switch without changing focus. It's not something that I normally do, so I just tested it out on my R5 with 3 different RF lenses. All switched from AF to MF without moving my focal plane. I'm sorry I can't be of more help, but this may be a case for a reset and test of the features you have enabled.
Newton
08-15-2023 09:20 PM - edited 08-15-2023 09:22 PM
You switch from AF to MF on the R5 and the focus changes. What happens when you switch back from MF to AF? Does the focus restore itself to what it should be?
Does it make a difference whether or not the metering timer is still active when you switch from AF to MF on the lens?
[EDIT] Check the “Retract Lens On Power Down” setting. It should not make a difference. Maybe it does.
