03-31-2023 12:32 PM
I received the email and updated my EOS R5. I read online, not Canon's website, that the IBIS high resolution shot only works for JPG and not RAW. Is this true?
03-31-2023 03:02 PM
It appears to me that the manual has a mistake and that IBIS high resolution remains enabled when the power is turned off and back on, but I have tried it only once.
https://cam.start.canon/en/C003/manual/html/UG-03_Shooting-1_0440.html
Take the picture.
Caution
Note
03-31-2023 03:07 PM
@John,
The above is very helpful. I don't have ibis and have been looking for more info on the feature. I knew output was JPEG. I should have looked for an updated manual. Thanks for posting this.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It
03-31-2023 04:03 PM
More information and apparent manual errors.
More general information: https://en.wikipedia.org/wiki/Pixel_shift
My wish list is for Canon to save the nine raw images as CR3 files and update DPP to include the algorithm for combining them. Next, adjust the sensor movement so that an IBIS high res image might be made with image stabilization, or at least with the optical stabilization of the lens. Some other camera manufacturers seem to provide programs for combining the images later on a computer and are able to make the feature usable hand held.
IBIS high res mode appears to work in 1.6x crop mode, but I do not see that in the manual. IBIS high res mode is disabled when DPRAW is enabled, but I do not notice that in the manual.
I am guessing that it might work especially well for photographing small objects in a light box where nothing is moving and the scene lighting is completely controlled.
I can see the IBIS high res mode helpful when photographing a distant small perched bird in 1.6x crop mode if I were carrying a tripod.
03-31-2023 04:17 PM
Maybe Canon was limited by the hardware on the EOS R5. I'm hoping this is resolved with the R1.
04-01-2023 03:05 PM
After removing the battery and replacing it, the menu item behaves as documented and IBIS high resolution is turned off when the power switch is cycled.
