EOS R3 Viewfinder Display icons
fjcanon
In the EVF of the R3, Does anyone knows what the flashing symbol/icon, which is positioned under the battery icon and to the right of the image counter represents?  This icon is positioned on the lower right of Electronic view finder.  I tried removing all the display icon on the view finder but it still shows up.
This icon does not appear on the screen.
Thank you.
Do you think it's because I have not configured the eye control as yet, this is why it is flashing?
Glad you found the culprit! Yes, it is likely flashing to indicate that it is not configured at this stage.  It should be worth the effort - although apparently results vary and the configuration can be repetitive as one is supposed to set it up in several different types of light.  I wish you good luck with the system - they say it's brilliant once it is set up and running.
cheers, TREVOR
Before you ask us, have you looked in the manual or on the Canon Support Site?
"All the beauty of life is made up of light and shadow", Leo Tolstoy;
7 REPLIES 7
Tronhard
Have you looked from Pg 1036-38 of the user manual for an explanation of viewfinder display symbols?
Link to a PDF copy Here
cheers, TREVOR
Thanks for your recommendation.  I was able to locate the icon in the manual on page 1032. It's the eye control icon. I haven't configured it yet so maybe that is why it is flashing.  As mentioned, at this moment it only shows up in the viewfinder and not the lcd display.   Just got the cam so i'm just starting to learn about it's features.  Thanks again Tronhard.
Eye ControlEye Control
Waddizzle
Flashing icons is typically how the camera calls for your help.  There is some set of conditions for which it cannot automatically compensate to achieve a correct exposure.  The flashing icon is the issue that you need to correct.
Sometimes the flashing icons are just warnings to alert you unusual shooting conditions.  You can define which warnings the camera will present to you in the displays. For example, if you are saving as JPG files and Picture Style is to Monochrome.
Thanks for your response, Waddizzle. Please see my response above. Do you think it's because I have not configured the eye control as yet, this is why it is flashing?
cheers, TREVOR
Awesome. Thanks again, Trevor
You are most welcome!
cheers, TREVOR
11/22/2022: New firmware available for EOS R3, EOS R7 and EOS R10
10/14/2022: Help ensure your autofocus is properly aligned with a Canon Precision Alignment
09/19/2022: New firmware version 1.0.4.1 is available for EOS C70
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
