09-30-2022 05:20 PM - last edited on 10-01-2022 08:58 AM by Danny
Just purchased the R3 and realized that there is a new firmware. It its ver. 1.2.1 the current one is ver. 1.1.1
How do I update my firmware?
I am a Mac user MacOS Monterey ver. 12.6. I already downloaded it from the Canon website. But when I copy the file to the memory card and go to tools page 6 on my R3 camera nothing happens?
Any ideas?
09-30-2022 05:24 PM
What file are you copying, and are you copying to the root folder (i.e. you should see the DCIM folder and the .fir file)
09-30-2022 05:25 PM
Hi and welcome to the forum:
To install the firmware on your camera, you will download a compressed file. You must open that up within you Mac, and this will give you a .FIR file. Once you have that, copy it to a formatted camera memory card.
To do the install, make sure the camera is fully charged, install the card in the camera. Under the wrench group in the menu, locate the firmware option and select that. It should be pretty obvious what to do from there on, so follow the instructions. You should actually have seen a set of instructions on this on the Canon Firmware download page, so check there for further clarification.
10-08-2022 08:26 PM
I have a similar problem as above. When I go to the R3 filmware and review the download versions for the MAC I do not find MAC OS Monterey V12.6 even listed. So the question would be where can I get the download for Monterey V12.6?? Thanks SBLANKSSR
10-08-2022 08:29 PM
The firmware is for the camera, not the operating system so much. I suggest trying to download the file, expand it to produce the .FIR file. Copy that to a SD card and load that onto the camera. In the menu system, under wrench set, find firmware. Select that and it will find the FIR file you then accept to update it and away you go.
Make sure that you have a fully-charged battery, and I recommend don't use a micro-SD card.
10-08-2022 08:35 PM
Sound good I’ll give it a try in the morning and let you know what happens. Thanks very much for your quick reply.
10-09-2022 10:33 AM
Good morning. Just wanted you to know that all updates for the R3 and R5 are completed as you recommended. Thanks so much for your help.
10-09-2022 01:58 PM
Good to know.
If you can please mark which post has the most correct answer as a solution, others with this issue may find the answer without having to post themselves.
10-08-2022 08:25 PM
10-09-2022 08:14 AM - edited 10-09-2022 08:16 AM
@Sblankssr,
Unlike device drivers which can be OS specific, firmware applies to the hardware (in this case the R3 body). The firmware file doe not change based on the operating system of your computer. The firmware is updating the camera.
The firmware download comes packaged or compressed in 2 formats. .dmg for MAC, or .zip for Windows.
The download must be extracted or unzipped. efore it can be used. Canon camera firmware is proprietary. The file type is .fir The .fir file is the one needed for upgrade. The one you will put in the root directory of your memory card.
1.2.1 Firmware Downloads:
Instructions are included with both downlads. They are in .pdf Acrobat format. Please ensure you are comfortable with the proces before proceeding.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It
