01-27-2023 07:33 PM - last edited on 01-28-2023 08:44 AM by Danny
I have an EOS R, with a Canon EF to RF adapter. I have been using this setup with a Canon EF 24-70mm f2.8 L USM lens for a year with no issues. Today I got a Canon EF 70-200mm f2.8 L lens. When attached to the camera and adapter, the camera will not turn on. The top screen is on but the camera will not function. When I remove the 70-200 lens, attach the 24-70 lens, and open and close the battery case, the camera will work.
What am I doing wrong? Is this lens not compatible? Did I purchase a bad lens?
01-27-2023 08:13 PM
Will the lens work on a Canon EF or EF-S Mount camera. If it doesn't you have a bad lens. If it works correctly on an EF or EF-S Mount camera the mount adapter could be faulty. The lens is compatible via the EF-RF Mount adapter. Does this lens have IS or is this a non-IS lens. Is the mount adapter Canon or a 3rd Party. Also which version of the mount adapter if its a Canon Mount adapter. The basic one, Control Ring or the one that filters can be installed in. Also DO NOT change lenses with the camera on make sure its OFF. Also DO NOT open the battery or memory card door with the camera ON.
-Demetrius
Current Gear: EOS 5D Mark IV, EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 50 F/1.8 STM, EF 85mm F/1.8 USM, EF 70-200mm F/2.8L IS III USM, 430EX III-RT, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D, Sigma 17-50mm F/2.8 EX DC OS HSM & EF 28-135mm F/3.5-5.6 IS USM
01-27-2023 08:13 PM
-Demetrius
01-27-2023 10:05 PM
Unfortunately I don’t have an EF Mount camera to check the lens. The adapter is the basic Canon adapter without the control ring. The lens does not have IS.
01-28-2023 08:36 AM
If the lens is shutting down the camera. The lens is faulty. A lens communication error won't shutdown your camera. I would return the lens.
-Demetrius
01-28-2023 01:12 AM - last edited on 04-21-2023 10:09 AM by Danny
Hello
Clean the lens contacts* to restore connection with the body. b) Try using a different memory card. All memory cards should be properly formatted in your camera prior to use. *Warning - Do not clean lens contacts on either a Canon lens or the camera body with an eraser! May be it will work for you.
01-28-2023 05:41 AM
@Compactvic
Greetings. Where was this lens purchased from?
Is it possible to take it to the retailer so it can be tested?
~CarePaks Are Worth It
01-28-2023 08:31 AM
It sounds like a bad lens. I would rule out repairs and pursue getting a full refund.
01-28-2023 10:09 AM
Yes. Exactly the direction I was heading in. Too many coincidences for a new lens.
