05-31-2013
03:42 AM
01:53 PM
I know for a fact that my Canon 6D has a limitation to sync flash speed at 180 maximum, but when I try to adjust the shutter speed to match that the camera allows me to set it at 160 or 200 only!
Anyone knows how to set the shutter speed at 180?
05-31-2013 09:59 AM - edited 05-31-2013 10:00 AM
Hmm, I don't think you can. 1/180 is an in between shutterspeed. In 1/3 steps you go from 1/200 to 1/160. Does your Exif data report a TV of 1/180? I don't own a 6D so I really don't know, maybe in full auto or when using HSS, the 6D forces an odd ball shutterspeed of 1/180. Otherwise it's got to be a typo in the their specs.
05-31-2013 08:40 PM
05-31-2013 10:33 PM
ScottyP,
Just for my own curiosity (I don't own a 6D), does the LCD display 1/180 and can you dial in 1/180 when flash is enabled or is it just the exif data that reports it used a TV of 1/180?
Thanks
05-31-2013 11:42 PM
05-31-2013 11:46 PM
@ScottyP wrote:
Hi, 7d5d,
You can dial in 1/180th when the flash is mounted and turned on as long as you don't have HSS enabled. As you try to dial up the shutter speed in Tv or M mode, it goes up to 1/180 and just stops going any higher.
Gotcha, thank for the clarification.
06-02-2013 02:33 AM
I guess he sorted it out, or sold the camera?
06-02-2013 07:47 PM - edited 06-02-2013 07:51 PM
If your exposure increment setting is 1/2 stop (under custom function), then you can dial 1/125, 1/180, 1/250.
If your exposure increment setting is 1/3 stop, then you can only dial 1/125, 1/160, 1/200, and 1/250.
It has nothing to do with the flash, and all Canon camera if you use the 1/3 setting you cannot dial in 1/180 regardless. And if you mount the flash on, like Scotty said, it will stop at the highest speed sync.
06-02-2013 07:53 PM
@hsbn wrote:If your exposure increment setting is 1/2 stop (under custom function), then you can dial 1/125, 1/180, 1/250.
Ahh, that makes sense. I've always used 1/3 steps.
06-02-2013 10:38 PM
