01-23-2020
09:35 PM
01:43 PM
I'm hoping someone can help me! I just received my 6d mark ii for Christmas in 2019. I went out for a shoot last week and noticed these dark black vertical lines in all my images. I changed memory cards thinking it was a bad card, but it kept happening! I turned the camera off and on, took out the battery, everything! Finally I changed it to video then back to camera and the lines were gone. Until I went to use it again a few days ago and the lines are on all my images again. HELP! I've attached a close up of one of the images where you can see all the lines
01-23-2020 10:34 PM
ashleynicole16,
We're sorry to hear that you're having difficulties with the EOS 6D Mark II. We recommend setting up a service ticket for this item at your earliest convenience at www.usa.canon.com/repair.
01-23-2020 11:01 PM
If you are still within your return window, exchange it with the merchant.
If not, Canon will fix it for you free as long as it hasn't been abused, dropped, etc.
Don't be discouraged. I love mine. One or the other will make it right and you'l be good to go.
~R5 C (1.0.5.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10
~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw ~Pixel6 ~CarePaks Are Worth It01-24-2020 06:35 AM
@ashleynicole16
Do contact Canon support, but be prepared to answer several questions. Which Canon lens are you using? Have you tried resetting your camera back to factory defaults? Are you shooting RAW, JPG, or both? Are you viewing these lines in the camera, on your computer, or both?
You may also wish to become more familiar with the menu settings that enhance the image quality. If you are shooting JPG, it would be best to disable all of the image correction and enhancement settings. Canon may be able to walk you through the steps on the phone.
01-24-2020 10:13 AM
Reset to factory before you do anything else. Unexplained actions can be easily corrected that way. Menu, tools, clear all settings and all custom settings. When you call Canon they will make you do it anyway. 1 (800) 652-2666
01-24-2020 10:27 AM - edited 01-24-2020 10:28 AM
Yes, does this show up in JPEGs? Is the above from DPP?
I seem to recall that some raw processors had problems with the dual pixels and showed them in images.
01-24-2020 04:38 PM
12-27-2020 10:19 AM - edited 12-27-2020 10:21 AM
I also have these weird lines, I did a factory reset, did a firmware update, cleaned the sensor, swapped out lenses and the problem still persists
Here's a link to the video containing the same problems https://drive.google.com/file/d/10OMYJfkeRxm0xU7i7fG3t_Nh_hFhrQpP/view?usp=sharing
it's a EOS Canon 2000D aka a T7
I belonged to a family member now deceased. Even if I never get it working I will still hold on to it for sentimental reasons but it would be nice. I have a Rebel SL1 and would like a backup
Please if the original poster has an answer let me know. is it worth sending in for repair if they decide to keep it and send me a refurbished one I might not risk sending it for sentimental reasons. But I also have no receipt because of the situation
The last picture is a portrait making the lines horizontal
12-27-2020 11:46 AM
" I did a factory reset, did a firmware update, cleaned the sensor, swapped out lenses and the problem still persists"
The only thing you did that might have helped was the reset. FW update was a bad, a really bad, idea. Unless you know exactly how, cleaning the sensor isn't a good solution. Not likely the lens either.
Most likely a failing sensor.
I don't know, but I doubt, a T7 is a good candidate for a new sensor but the only way to know for sure is to call Canon.
1 (800) 652-2666 they will guide you.
12-27-2020 12:16 PM
@xlnyc wrote:I also have these weird lines, I did a factory reset, did a firmware update, cleaned the sensor, swapped out lenses and the problem still persists
Is the above image the entire photo? Has it been cropped? Is it a screenshot?
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
