11-02-2015 07:59 PM
Hi folks. Here's a quick video of my issue. What are your experiences? Any creaking?
11-03-2015 11:33 AM
I purchased it new in September on Ebay but it is grey/import model so I don't they wanted to assist me with it at Canon Service NJ. I ended up opening the grip a bit by taking out the screws on the side, bottom, and left screw above the lens mount. I found the creaking was coming from the plastic front plate binding against the top plate. I discovered this by pushing down on the top plate near the shutter release while squeezing the grip. I noticed the creak went away. So the fix was to push a bit of plastic grocery bag into the gap between the body panels. Worked like a charm. Just took a bit of scrap plastic to fix a bit of scrap plastic. 🙂
11-03-2015 10:21 AM
Not normal. Is is still under warranty? Send it back in and explain the issue. You got hold of a dumbell.
11-03-2015 11:33 AM
11-03-2015 11:48 AM
Did you save money buying grey market? Usually it is not worth it. Especially cosidering Canon's normally excellent service department.
Were you trying to get it done under warranty? Canon USA does not cover grey market gear. I always recommend avoiding grey market unless you are buying used. A new grey may be a better buy than a used one. No warranty involed!
11-10-2015 07:04 AM
11-10-2015 09:15 AM
I bought my first Canon USA camera in the early '80's. I have never looked back. Canon USA, CPS, has been very good to me over the years. Yes, I agree it is expensive but the best usually is.
Two roads to travel. I hope yours is as successful as mine has been.
