03-14-2023 04:04 PM
03-14-2023 05:00 PM - edited 03-14-2023 05:02 PM
What form does the radio interference take? Are you hearing taxi drivers talking to each other? Or broadcast radio? Or is this a 'buzz'?
Radio interference is usually a combination of a poor electrical connection somewhere acting like a diode, and a wire of a length that resonates with the interfering radio signal wavelength, acting as an aerial to inject the interference. Therefore I would double-check the mating surfaces of your audio connectors, and try a different length of mic cable.
I have an R6mkII myself and haven't experienced this problem, nor have I heard of others having such trouble. I hope you get it solved!
03-14-2023 05:07 PM
Thanks yea it mostly seems to be radio, as its music playing and general static stuff. Happens in every location I've been to in multiple states, but yea only with the R6mkii. Im using balance cables too fyi, so I don't think this should be an issue.
03-14-2023 06:05 PM - edited 03-14-2023 06:33 PM
Balanced cables? The audio input on the camera is not a balanced input. The only way I know of to make a balanced circuit to a microphone is using a third party audio interface such as the Tascam CA-XLR2D-C professional audio interface which connects to the multi-function shoe on the camera.
The 3.5mm jack audio input of the camera is unbalanced stereo TRS (tip-ring-sleeve). A proper balanced mic circuit should be immune to radio interference but you can't achieve that just by using a 'balanced' cable - which won't be balanced if not part of a balanced input circuit. A balanced cable is one where the audio signal is carried on a twisted pair of conductors which are surrounded by a braided or lapped shield conductor which is earthed at one end and not itself part of the signal circuit. The connectors are usually but not necessarily XLR.
An unbalanced cable has just one central conductor per channel, and the outer braid forms the return half of the audio circuit. It is therefore capable of picking up and injecting radio interference into the audio. The connectors are usually but not necessarily jack, either 1/4" or miniature 3.5 or 2.5mm.
The three connections of the camera 3.5mm jack audio input are Left live, Right live, and common return. There is no connection for an earthed external braid. If you're using a conventional 'balanced' cable, you need to connect the twisted pair of signal wires to Tip and Sleeve (for the left mic channel) or Ring and Sleeve (for the right mic channel). Leave the outer braid unconnected. This won't result in a real balanced circuit but might work, depending on the circuitry in the mic itself. If it doesn't work like that, try connecting the outer braid together with the signal return to the Sleeve.
I can't explain why you have this problem with the R6mkII but not with the R6. I have used both and not had the problem, but audio circuit differences might explain the mkII being less forgiving of inappropriate interconnection of microphones, perhaps?
03-14-2023 06:17 PM - edited 03-14-2023 06:18 PM
I found this statement in the manual:
Sounds from Wi-Fi operations may be captured with built-in or external microphones. During sound recording, using the wireless communication function is not recommended.
03-14-2023 06:41 PM
Cool thanks. I have both, balanced and unbalanced, tried both, just though balanced ones would be helpful in this case. Either way its the same set up I've used to capture audio for interviews my whole career, 15 years +. Works great on everything except the mkii. If anyone else has input, I'd appreciate it.
03-14-2023 06:48 PM
It's always possible your camera has a faulty mic input socket.
03-14-2023 06:51 PM
Yea I think its something like this maybe. Something faulty.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
