11-07-2022 09:30 AM
Hello,
Does anyone here know if Canon EOS Rebel T8i 850D would be suitable for live streaming via hdmi out?
Is there a risc of overheating and shutdown, if used for streaming (1080p, 50 fps) for several hours (at least four hours in a row) via the hdmi out port, at normal room temperature, with autofocus on?
I intend to buy a camera for live streaming and I was considering Canon M200, Rebel SL3 and this model, T8i 850D.
11-08-2022 12:53 PM
@florinp wrote:Hello,
I think you would need a professional camera for that type of requirement.
11-07-2022 01:44 PM
If the camera features “Clean HDMI Out”, then streaming should not be an issue. It is a Rebel Series camera, so I do not think it features Clean HDMI output.
Overheating is always an issue with any camera. Professional cameras contain internal fans. DSLRs do not.
11-08-2022 04:23 AM
Hello, thank you for the reply! According to the manual, it does have clean HDMI output, both 4K and FullHD.
As to overheating, I think it depends on a number of factors, resolution, whether the camera is recording on the card or not, AF being used or not, and so on.
My guess is that only actual experience with this camera under the specific use-case scenario can tell, this is why I am asking on this forum.
11-07-2022 05:15 PM - edited 11-07-2022 05:17 PM
florinp,
I don't know if this will have a bearing on your decision, but the manual says that with HDMI, there will be no sound output.
I think that to use your T8o as a webcam, you use the USB port.
Read, "Can I Use My Canon EOS Rebel T8i As A Webcam?"
https://www.photographypursuits.com/canon-eos-rebel-t8i-as-a-webcam/
Steve Thomas
11-08-2022 04:38 AM
Thank you stevet1, this is useful information.
I route sound separately via XLR cables, so, not having sound via the hdmi cable from the camera is not an issue.
The USB solution will not work for me, what I need to do is send the hdmi signal to a hdmi video switcher.
There is a post here on the forum from one user who says that after 40 minutes of live streaming, the display of the camera turns off. He does not say that the hdmi video signal stops. Basically, this suggests the camera is capable of live streaming at least 40 minutes.
What I try to find out if it would overheat or not, if used for longer periods (four hours at least), and with Dual-Pixel AutoFocus on. I saw that on other camera models, some users disable autofocus while live streaming, to avoid overheating issues.
11-08-2022 10:43 AM
florinp,
I ran across a website that addresses how to livestream using HDMI on a Canon SL3 for people who intend to stream out video on the Internet. You might find it helpful.
Please Note: That I do not have any connection with or stake in any of the products or software they mention in their article.
https://www.photographypursuits.com/canon-eos-rebel-sl3-hdmi-webcam/
Steve Thomas
11-08-2022 12:53 PM
11-14-2022 05:50 AM
Thank you, you are right.
