Search instead for
Canon EOS 80D :: cant connect on Wifi
M_Malhas
Occasional Contributor
Hello Fellows,
Currently i cant connect my Canon 80D to a Windows 10 64-bit PC over WiFi. i have tried a couple of things so far and i havent gotten successful. im not sure where to go with this, any help or insight would be very much apperiated. here is what i have tried so far :-
  • Updated Camera Firmware to the latest (1.0.3)
  • Made sure that Network Discoverability is on (both in the settings and when connecting to a wireless device)
  • Checked that the Camera can connect to a Smart Phone over the same network
  • Connected the Camera using a USB to the same PC
  • Uninstalled all EOS Software off the PC and re-Installed it again
  • Cleared the wireless settings on the Camera, and tried to pair
M_Malhas
i got it to work on another pc, using another version of the utility software. somehow the version of the EOS Utility out on the US site here was not working, not sure why the camera was not accepting the pairing on it. on the other pc i installed the UK version on my machine it just poped up into the EOS Utility. Uninstalled it on the first pc and it also worked there.
Thank you John & Thank you Wadizzle
17 REPLIES 17
I don't know if this will help:
Canon Knowledge Base - Using EOS Utility 3.x to Send Images to a Computer (Wi-Fi Function) (EOS 80D)
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
M_Malhas
Thank you john,
i went through the link and done everything (till step 3-8) , still i cant get past the pairing. i also checked with EOS Utiltiy 2 & 3 to see if the camera is added before, sadly still unsucessful with connecting both devices. also i started suspecting its a firewall issue and i added both "EOS Utility" and "EOSUPNPSV" similar to what is done in the post (EOS Utility firewall problem)
@M_Malhas wrote:
Thank you john,
Reset the Wi-Fi, so that it uses the default name for the camera.  You probably need to go into the Programs folder and start the "EOS Launcher" manually, just for the first attempt.  With many PCs the EOS Launcher will start up when you connect a USB cable, instead of the EOS Utility.
Your camera needs to connect to your LAN, not to your PC. Make sure your the security on your wireless access point is allowing for new onnections, but you should see this from the camera end.  It will either connect to your LAN, or it won't.
M_Malhas
hello waddizzle, thank you for taking time off and writing your post.
i have tried the following:
  • restarted my router & pc
  • cleared settings on the camera
  • launched the "EULauncher.exe" with admin rights and allowed it on windows firewall
  • made a wifi set on the camera and connected to the network (btw i see the camera on the pc in network)
still getting this in the laucher
Did you get past the point of router pairing? That seems to be where many folks get hung up. Some routers have a software "button" and others have a physical button.
M_Malhas
Here is the situation on the camera
The camera cannot do the pairing all by itself.  It seems like it is not connecting to your WAP.  Check your security setup in the router.  This would require the router software, not the Canon. EOS Utility.
M_Malhas
it is connected to the Network, the PC im trying to pair with can even see it in the network. also the camera is on the router's tables.
You need to get past this step.  You must connect the camera with the Wireless Access Point, WAP, for your LAN.
