06-16-2021 10:55 AM
So in the last month my 77D wich i got 2/22/19 has decided not to turn on at random times. I have to pop the battery out and back in and then it will turn on but its frustrating because i've never dropped it, no water damage... its an 800 dollar camera i waited a long time to get, so ya, i take care of it.
Also recently cleaned the censor off due to dust, and now its having problems with my macro extension tubes and sometimes lenses being removed while its on... which sometimes i have to do to lock in the F stop.
I don't know what to think happened. its BS honestly given it just hit two years recently, but i can't find anything regarding the 77D online hardly so i figured i'd ask here, see what i could find out. thanks
06-16-2021 11:06 AM
How old is the battery?
Did you clean the sensor yourself, or did you send it in to a service center?
06-16-2021 11:18 AM
I live in a small farming community, i can't afford the trip to Kansas city to get to the service center. this is the only time its had these issues and yes i did clean it myself, i've got the liittle pocket rocket tool and brush so i didn't use any force or products that would cause moisture.
06-16-2021 12:11 PM - edited 06-16-2021 12:11 PM
@rosalind1347 wrote:I live in a small farming community, i can't afford the trip to Kansas city to get to the service center. this is the only time its had these issues and yes i did clean it myself, i've got the liittle pocket rocket tool and brush so i didn't use any force or products that would cause moisture.
Brush? That does not sound good. They sell moistened swabs to clean an image sensor. Cut to specific sizes.
But, a dirty sensor should not spot the camera from turning on. If you remove the memory card and lens, and it still does not turn on, then you KNOW that you have an issue with the camera.
Make sure that the door to the memory card slot and battery compartment are securely closed. If you have a battery grip, remove it.
