Canon 750d Camera vs SD Card
kaone
Hi. Please need some assistance. I have a canon 750d that does not switch on when i insert the sd card inside the camera. Once i eject the sd card and switch on the camera it switches on and i can do functions as usual but once i put in an sd card no powering up. Is the sd card slot damaged? Thanks in advance.
13 REPLIES 13
My T5 would hang.  All of the entry level ####D bodies seem to have issues with SDXC cards. This would be a first that I have heard about issues on a beginner ###D body.
BurnUnit
Whiz
LOL.  I remember that post.  It was quite the surprise.
BTW, the OP still has not confirmed that full size cards are actually being used.
Lotus7
Rising Star
The 750D/T6i Firmware fully supports SDXC (2TB limit) and is not restricted to SDHC (32 GB) only.
Since the OP states that two cards work on another 750D, they must be properly formatted to FAT32 and not NTFS.  Even an improperly formatted card should not cause the camera to not turn on -  it might trigger a "card must be formatted" warning, but should not prevent the camera from powering up.
However, strange system faults can occur, and it certainly can't hurt to find a 8GB or 16GB SDHC card (if you still can) to try to absolutely eliminate the "card size" issue.
11/22/2022: New firmware available for EOS R3, EOS R7 and EOS R10
10/14/2022: Help ensure your autofocus is properly aligned with a Canon Precision Alignment
09/19/2022: New firmware version 1.0.4.1 is available for EOS C70
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
