Canon 5D Mark IV stops recording at 30minutes, will not rollover to new file.
Sub7th
Hey all,
My 5D IV keeps stopping at 30 minutes instead of rolling over to a new file.
The card is not full, and doesn't seem to be corrupted, it is a 256GB Sandisk Extreme Pro, 170mb/s
I also format my cards before each new project, so it was formatted (internally) this morning.
I'm recording 1080 all-i at 30fps, using .mov.
Not sure what's going on or if I am doing something wrong / missing a setting.
I haven't had this issue with he camera until yesterday.
Any ideas?
rs-eos
I think the 5D IV is limited to 30 minutes max recording.   One workaround is to use an external recorder (see page 388 of the user manual which has a special setting to enable for allowing longer output over HDMI beyond 30 minutes).
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
2 REPLIES 2
rs-eos
Ricky
@Sub7th,
Ricky hit it on the head.  The 5D4 will only record for up to 30 min.  After the recording stops, you should be able to start filming a new movie file again.  As long as the camera is not overheating, has power and space on its memory card, a new file should be generated.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
Avatar
