Canon 5D Mark III Overheating Issue
crfoto
Hi! Thanks to anybody reading this entry.
In advance I would like to apologise for my English. I'm Dominican.
Back in May, I purchased a second hand 5D Mark 3, and started using it for all my jobs. I'm a wedding photographer, and I have previously owned a SL1, a 60D, 6D and now my 5D 3. My camera has about a 75K shutter count, and over time I have noticed how my camera will overheat within about 6 minutes of recording, about 8 minutes in live view and if I'm only shooting pictures, it will take about 20 minutes under direct sunlight to fully shut down and stop working. I use both LP-E6 and LP-E6 N batteries. I shoot with Sandisk Extreme Pro cards, both SD and CF. Even when just using live view with no memory card the camera will overheat and while recording with just one card it will still shut down in the times mentioned above. I have shot in indoors with optimal temperatures, and the camera will still overheat, I use Sigma Art and Tamron G2 lenses so it's not because compatibility issues or anything else I could say, I use Canons 600EX flashes too. So I guess there shouldn't be any issues with my setup, however the camera still manages to overheat. I don't know what else to try, and since we don't have canon authorized service here, I don't want to put my camera in anybody's hands. Has anybody experienced something similar? Any advice or questions?
3 REPLIES 3
Waddizzle
Send it in to Canon, and have them clean and check it out.  Since it is used, it is probably a good idea, anyway.
Most any DSLR sensor will eventually overheat after extended use in video mode.  Most of the time Live View mode will shut itself off after a minute or so.  But, I would think you should be able to get more than a few minutes of video from a 5D3.
jrhoffman75
Do you see a difference if you are shooting indoors in an air conditioned facility versus outdoors in high temperatures?
wq9nsc
You may have a temperature sensor issue that is shutting down the camera sooner than needed but a DSLR is still primarily a still image camera with some ability to shoot video.  The 1DX series is probably the best of the Canon DSLR bodies at standing up to video shooting with its large body and heat pipe cooling design that dumps heat to the battery compartment but it is still very much constrained by the need to make a DSLR weather and dust resistant rather than providing optimized cooling for video mode.
I picked up a Canon XF-400 camcorder for doing sports video work.  Drawbacks are I can't use my collection of EF lenses for it and it is definitely not weather resistant like a 1 series body but it shoots continuous video without thermal concerns.  It has forced air cooling which by default runs continuously but can be set to temperature activated mode to conserve battery life. That same fan will pull moisture and dust into the body which would be death to a typical DSLR.
In direct sunlight these black camera bodies soak up a lot of heat so if ambient temperature is high I can understand it overheating even in standard still image mode.  Its only way of dumping internal heat is via transfer through the case and when the case temperature goes high from direct sunlight then the internal temperature is going to quickly reach an extreme temperature range.
Rodger
Canon LIVE! Canon LIVE!
