05-30-2023 12:50 PM
Canon 5D Mark 4. EF24-70mm f/2.8L USM
Three photos below have:
ISO 800, f/11
Shutter speeds 1/200s, 1/320s, 1/500s
After 5 years of owning my Canon 5D Mark 4, which has never behaved strangely, yesterday suddenly a strange thing happened - some photos began to look incorrect - as if part of a photograph with a changed color. What could it be?
05-30-2023 06:16 PM
How are you downloading your images? If using a card reader, try a different card reader and a new cable. A bad card reader or cable can corrupt images.
05-30-2023 12:54 PM
Fault with the sensor perhaps? Most rows only returning green data (no red or blue)?
Maybe try a different SD and/or CF card to see if that makes any difference.
Also try resetting the camera in case there's some feature that is causing this (dual pixel RAW? corrections such as peripheral illumination?)
05-30-2023 01:03 PM
Hi Ricky.
Thanks for the quick answer. I'll try to reset. But these issues happen not too often, so it is hard to replicate it. I'd say - chance to replicate it is 1 by 30.
Some has magenta hue:
Some has neutral, but different in brightness:
05-30-2023 01:26 PM
Sounds like a bad memory card or a bad image sensor.
Changing your memory card to a new one is easy to do. Be sure to format the card prior to first use.
05-30-2023 06:13 PM
Hi Waddizzle. That's interesting. I'll try it for sure. Thanks!
Alexey Cheprakov
05-30-2023 06:16 PM
05-30-2023 07:42 PM
Hi 5DIV!
You're right. As soon as I re-inserted the card into the reader, the problem disappeared. Brilliant! Thank you very much!
Cordially,
Alexey Cheprakov
05-30-2023 09:16 PM
Good to hear that you figured it out.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
