07-18-2016 01:09 PM
I own the Canon 1100D, and so far I've taken photos in Landscape Mode. Recently, I take pictures using Manual Mode,and whenever I connect my camera to my pc, it won't show my photos unless I shot it using Landscape Mode. Even if I take 10 Manually shot pictures and then one photo using LS Mode, it will only show me that one photo. What can I do in this situation ?
Note: I'm not using the Protect Images feature.
07-19-2016 12:19 PM
Since you can see both the Landscape and Manual photos on the camera LCD and you feel they are properly exposed there is no reason they should both appear on the computer.
So, you need to give us as much specificity as possible about the computer setup. Windows or Mac. Which Windows 7, 8 or 10.
What software are you using to download the files from the camera via USB.
WHat software are you using to view the files.
For the "missing" images you can get the filename from the camera LCD. Try searching for that file name; from the example use "-0032" and see if you can find them on computer.
07-18-2016 01:35 PM
@idanidan123 wrote:I own the Canon 1100D, and so far I've taken photos in Landscape Mode. Recently, I take pictures using Manual Mode,and whenever I connect my camera to my pc, it won't show my photos unless I shot it using Landscape Mode. Even if I take 10 Manually shot pictures and then one photo using LS Mode, it will only show me that one photo. What can I do in this situation ?
Do you see them if you look at the card through a card reader instead of through the camera? IOW, have you verified that the pictures are actually on the card?
07-18-2016 01:42 PM
Do you understand manual mode? If you're not close on your settings there won't be a photo, just an over or under exposed frame.
07-18-2016 02:05 PM
Landscape Mode is a "Basic Zone" shooting mode, which basically means the camera automatically sets the exposure for you, but optimizes it for a particular type of shot. All of the "Basic Zone" shooting modes set the exposure for you.
Manual Mode is a "Creative Zone" shooting mode [P, Av, Tv, M and Bulb]. The Creative modes require that you set one or more legs of the "Exposure Triangle", in addition to some other optional settings. In other words, you must dial in exposure settings yourself, or it is highly likely that you will wind up with images that can be unviewable, completely dark or bright.
07-19-2016 05:11 AM
07-19-2016 05:12 AM
07-19-2016 07:55 AM
If you remove the card from the camera and put it in a card reader are the files on the card?
07-19-2016 09:18 AM
@jrhoffman75 wrote:If you remove the card from the camera and put it in a card reader are the files on the card?
Yeah. Can you even play back and see the photos in the camera?
07-19-2016 09:47 AM
If you can see the photos on the camera's LCD but not on your computer they may be RAW & you haven't installed software to view the RAW files.
07-19-2016 10:55 AM
