07-21-2014 11:48 PM
07-22-2014 03:54 AM
You are asking about the Tamron AF18-270mm f/3.5-6.3 Di-II VC PZD AF Lens for Canon? It is a 15x high power zoom lens designed exclusively for digital SLR cameras using the more compact (APS-C) digital size image sensors like your Rebel T5.
The focal length of this lens is equivalent to 28-419mm in Full Frame format. Designed as an "all-in-one" lens, it meets almost all photographic opportunities.
You are not trying to put your Mom's brand-N lens on your Rebel? That won't work.
07-22-2014 08:07 AM
You need to buy that lens with a Canon mount and YES that will fit & work on your camera. Canon makes an 18-200 & I think Sigma has an 18-250.
07-22-2014 11:41 AM
07-22-2014 01:45 PM
07-22-2014 02:18 PM
07-22-2014 03:40 PM
There is a tamron 18-270 lens you just need to buy it with a canon mount and it will fit and work fine
07-22-2014 05:08 PM
Tamron currently sells a version 2 of the 18-270 and it's supposed to have a better & faster AF setup than vewrsion 1, which I did own & thought was a pretty good all in one for it's price. HOWEVER from what I've read the Sigma 18-250 may be an even better choice so do a bit of homework before buying. I recommend starting here.
http://photography-on-the.net/forum/showthread.php?t=1315477
and here
http://photography-on-the.net/forum/showthread.php?t=599376
And if you can give up a bit on the long end here for the Canon 18-200
http://photography-on-the.net/forum/showthread.php?t=578814
07-22-2014 06:09 PM
07-22-2014 09:55 PM
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
