06-26-2016 09:28 PM
I am in a well lit room and for some reason I cant get my camera to take pictures without the flash. When I do take them they show up as black. How do I adjust the Exposure comp./ AEB setting?
06-26-2016 10:05 PM
By learning how to use your camera PROPERLY. In MANUAL mode it's up to you to set it correctly using the built in light meter which displays info that you can see through the viewfinder. Your Manual will cover how it all works.
06-26-2016 11:13 PM
Manual presumes you will manage the entire 3-variable exposure calculation and the light metering yourself.
If you are unable to balance shutter speed, lens aperture size and ISO Setting, you cannot use M mode (Manual).
If you have learned the "exposure triangle" from books or from free Google videos you will have the needed basic principle.
Full Manual is not used a lot even by enthusiasts because the modern camera will let you choose to control either the aperture value (AV mode) or the shutter speed (Time Value or TV mode) and the camera will set the other values for you for a correct exposure. I only use Manual when using flash myself. If you are not a seasoned veteran of film photography, nor a serious digital student, you probably don't need to be using Manual much.
06-27-2016 08:11 AM
@ScottyP wrote:Manual presumes you will manage the entire 3-variable exposure calculation and the light metering yourself.
Just to be clear, the camera does do the metering for you, even in manual mode. It just doesn't go ahead and alter its settings to match the metering data. You actually have to turn the wheels yourself.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
