09-16-2018 12:44 PM - edited 09-16-2018 01:04 PM
How do I set up back button focus in the 6D Mark II? I have a lot of instructions on BBF for the 6D, nothing for the 6D MarkII.
I am scrolling to C.FunIII. Then I get a series of pictograms, and I have no idea what to do to set up BBF. I am having trouble understanding which pictogram means what.
06-16-2019 06:17 PM - edited 06-16-2019 06:20 PM
@47greyfox wrote:I read all the post's threads. The pages identified were 500 and 501. Not 497, a more logical starting point.
“I am scrolling to C.FunIII. Then I get a series of pictograms, and I have no idea what to do to set up BBF. I am having trouble understanding which pictogram means what.”
Gee, look at that. Page 497 looks just like the screenshot that the OP posted, which is exactly what the OP does not understand. The pictograms are not explained anywhere on that page. Pages 500 and 501 explain which pictograms to adjust for BBF. Thank-you.
06-16-2019 06:49 PM
I see your point even tho the posting didn't have the entire manual page. I guess my thought is that there was a lot of wasted space with very little info imparted, whereas, a simple walk thru would've done the trick.
09-16-2018 01:42 PM
@rdixit wrote:I am editing my original question to make it more clear. I will also try to attach a photo of the "pictograms"
[ Button ]. : [ Function ]
09-16-2018 10:12 PM
The [Shutter] button needs to be “Metering”.
The [AF-ON] button needs to be “Metering and AF Start”, which is seems to be the factory default. This is also the default setting for the [Shutter] button.
09-22-2018 08:40 PM
If you cannot understand that, then you need to contact Canon Support so that they can walk you through it.
09-16-2018 01:39 PM
@rdixit wrote:How do I set up back button focus in the 6D Mark II? I have a lot of instructions on BBF for the 6D, nothing for the 6D MarkII.
If you have instructions for the 6D, then use those. The major difference is where to find the menu, which you seem to have found.
09-27-2018 07:55 AM
