Search instead for
Back Button Focus vs Speedlight Auto Shutoff
rhodesmk
I set the "star" button on my Rebel T3i to use as my back-button focus. Now that I'm discovering/experimenting with flash photography, the directions from my owners manual state "To cancel the slave unti's auto power off, press the camera's <*> button."
Is there an alternative? Right now, if I press this star button, I'm focusing, and I don't see this canceling the Speedlight's auto power off function.
Thanks!
3 REPLIES 3
Waddizzle
Thanks!
Which model of Canon flash?  Depending on the AF mode and shooting mode, you should be able to press the shutter and get the same result.
Do you understand the nomenclature used to describe how the buttons are programmed?  It works like this.  See the slash?  Look at how the button programming options are written.
[Function 1 / Function 2 ]
The ‘Function 1” describes what happens when you press the Shutter, while “Function 2” describes what happens when you press [*] button.
Look at the function for the default behavior, Option 0, I think it is.  By default, the [*] button is programmed for {AE Lock}.  Your BBF programming now puts [AE Lock] on the shutter.  Either way, either the shutter or the [*] button should do what you need.
My Speedlight model is a 430 EX II.
It sounds like you are saying that since I assinged the "star" button to Back Button Focus, that now the shutter button will take over the speedlight auto shutoff function.
Did I understand you correctly?
I am not near my camera today, so will check this out later this week, just wanted to make sure I understood you first.
Thanks,
Tim
Hello Rohdesmk,
The shutter button will keep the Speedlite from auto powering off, because it's keeping the Speedlite active.
06/30/2022: Service Notice: EOS 70D: Error 70 or Error 80
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
03/22/2022: New firmware version 1.2.0 is available for PowerShot PICK
03/16/2022: New firmware version 1.5.2 is available for EOS-R5
03/16/2022: New firmware version 1.5.2 is available for EOS-R6
02/07/2022: New firmware version 1.1.1 is available for EOS-R3
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
12/7/2021: New firmware version 1.3.0 is available for Mount Adapter EF-EOS R 0.71x
12/7/2021: New firmware version 1.1.1 is available for CR-N 300
12/7/2021: New firmware version 1.1.1 is available for CR-N 500
12/2/2021: New firmware version 1.1.0 is available for RF 70-200 F4 L IS USM
