As I waited for the 5DIV
Edward
Enthusiast
I was considering the 1Dx MKII.  Hoping for Canon to make these cameras more in similarities as to the lay out of the button functions and improvements. Examples:
5D MK IV:
1. Why not the ISO selection button and the top illuminatio button in the LCD panel moved to the same location the 1DX II?
2  Why was the ON/OFF not moved from the left top of the camera to the rear right in a similar locations as the 1Dx II?  At one time it was located with the multi function lock switch in the back of the camera where it was easier to operate particularly when using long lenses.  Also the groove where the switch of the camera is now, allows for water to acummulate probably able to cause a water leak into the camera.
3.  The Rating Button may be good for photo newbies but any serious photographer would not use that button since the JPEG image in the back LCD is not good enough to rate images.  And to add injury, this button cannont be programmed for something more useful.
4. The exposure level indicator in the 5DIV is at the bottom of the viewfinder while in the 1DX MKII is vertically in the right side of the viewfinder.  It's location will b
22 REPLIES 22
Because the automatic sleep setting uses power and in cold conditions the battery efficiency decreases.  I carry extra bateries inside my cold gear close to the body to keep them warm.   When you are waiting for the action, it takes hour before something comes along. Also, at times there is no place to charge batteries.  For example, last March I was in the Himalayas searching for Panda bears (never saw one) and the area is not electrified, so I had to rely in the 8 batteries that I carried. Could not recharge until I got back to the lowlands.
Sorry, same name for similar indicators.  I was referring to the AEB one at the bottom with the -3 to +3 scale.
You might want to consider a Goal Zero Guide 10 Solar Kit to recharge your batteries.
Again, if it is below 32ºF, or in other words below the designed operating temperature range of the camera, the small amount of heat generated by the electronics can help prevent damage to the camera. The recent extremely cold winters lead to numerous shutter failures, particularly on the 70D.
The 1DX Mk II has that in the same place as the 7D Mk II. The viewfinder screens of the 1DX Mk II and the 7D Mk II have very similar layouts.
The problem is how much gear can one carry.  Already carrying 40 pounds and walking in the cold between 10-12,000 feet is not fun.
@TTMartin wrote:
You might want to consider a Goal Zero Guide 10 Solar Kit to recharge your batteries. ...
If you find yourself in Iceland in the winter, good luck finding sunlight strong enough to power a solar charger!
Bob
Edward
Enthusiast
Correct; I was there in January and suffered $1257 of equipment damage when the tripod fell.
The example he gave was at 10,000 feet in the Himalayas. At 10,000 feet you have half as much atmosphere filtering the sun so solar panels are more efficient there than at sea level.
As far as weight goes, I was researching them for an AT Thru-Hike. It weighs 1.5 lbs (solar panel, 4 AA batteries, and AA charger which doubles as a USB battery bank), and can strap to the top of your backpack so they work even as you are hiking.
"The example he gave was at 10,000 feet in the Himalayas. At 10,000 feet you have half as much atmosphere filtering the sun so solar panels are more efficient there than at sea level. "
I thought he made a different point.  How many hours of sunlight do you get each day in Iceland in the middle of the winter?
