05-16-2013 09:10 AM
05-16-2013 10:46 AM
Yes, this is what everyone was hoping they'd fix with the first firmware update. Seems they decided to pool their resources and tackle that horrible issue with the Date/Time/Zone values resetting themselves. Glad they got that fixed.
05-16-2013 01:04 PM
05-16-2013 01:51 PM
No doubt about the white balance button. I don't use GPS so it doesn't bother me, but I just think it's sloppy engineering on Canon's part and I think not fixing it shows their apathetic corporate side.
05-16-2013 01:54 PM
05-18-2013 03:54 AM
05-18-2013 10:12 AM
OFF means OFF 🙂
08-27-2013 05:15 PM
6D battery drain - "Work Around"
Install the Canon Battery Grip.
Step 1. Turn the battery lock to Open.and leave it unlocked
(Batteries are now disconected from camera)
Step 2 Use a rubber band to hold battery tray in.
NOTE:: If Canon will not make a fix, possibly the after-market suppliers of the 'Grip' will make a three position latch.
A 'Modified' grip could easily be manufactured by modifying the tray and latch assembly.
Position 1. Power disconnected and tray locked in (6:00 clock position)
Position 2. Tray unlocked (Similar position as present)
Position 3. Tray is locked and power is connecd. (Same position as present and battery drain will continue as it does now..)
GET WITH IT CANON.... or let the after-market fix it with their 'Grip'
Bill
08-28-2013 12:06 PM
07-01-2015 02:35 AM
The Magic Lantern (http://www.magiclantern.fm/) is said to have this feature, but I have not tried it myself.
Gee... pretty annoying having to use a 3rd hack for a $2000+ camera, just because Canon don't know that OFF means OFF.
When you turn the camera OFF, often you put it away some place where there is no GPS coverage, for example inside a house or in the trunk of a car, so it really makes no sense burning battery to look for GPS, with the disadvantage that next time you try to turn the camera on, there is no battery left.
Canon should really fix this in a firmware upgrade; also for the 7D Mark II that has the same annoying problem.
