01-12-2025 12:21 PM
I've just upgraded from the 5D mark4 and I my camera cannot find any wifi networks other than 2.4g
I have the Asus mesh with the main router being a BE98. So I have wifi 6 and 7. I've tried creating a separate network with 5g and 6g but it still does not see it.
What am I doing wrong?
01-12-2025 01:10 PM
Your camera is compatible with 2.4 GHz, 5.0 GHz, and 6 GHz Wi-Fi:
From the product page on our site:
Also in the spec sheet, it says it supports the below frequencies and bands:
For 6 GHz, it specifies that the Authentication must be WPA3:
01-12-2025 01:51 PM
Thanks my settings are correct. Even if i try and manually add the wifi name it does not work. I will try with the wifi router my network gave me and see if it picks that up.
01-12-2025 02:40 PM
Do you happen to have it set to not broadcast your SSID? Some routers do that by default—for security.
01-12-2025 04:44 PM
No it's broadcasting
It also doesn't pick up my isp wifi.
Only 2.4ghz
01-12-2025 05:14 PM
6GHz is infrastructure only and camera AP is not supported.
Wi-Fi use may be restricted in certain countries or regions
Does this mean the camera will not connect to 5g and 6g
I use a file server over wifi n 2.4g is too slow.
On my 5d mark4 I had a network cable to a portable router
R5 m2 does not have a network port and do not want the battery pack
