12-07-2019 02:45 PM
If I use WiFi to tether my Mark IV to my Windows 10 desktop computer I can successfully open Digital Photo Professional 4 and control the camer, EXCEPT for actually taking a picture. When the shot is composed and ready to take the message window to the left of the on-screen shutter release button has a warning message that states "No more shot [sic] is available." If I press the shutter release on the camera the topp display flashes "FULL" in the upper left corner where white balance is displayed. There is a freshly formatted (in camera) SD card and a freshly formatted (in camera) CF card. If I close out of the EOS utility I can shoot thousands of photos. Any advise on what I am doing wrong that causes the remote shooting window to show "FULL" ???
12-08-2019 08:03 PM - edited 12-08-2019 08:04 PM
Does your app have write access to the folder? You might try running the app as administrator.
12-09-2019 03:10 PM - edited 12-09-2019 03:11 PM
@CaliforniaDream You, my friend, are a genius! The "FULL" is, in fact, referring to the destination volume. While DPP4 can read, edit and save files in the folder I had selected, when I launch the Remote Shooting app (from DPP4 or EU the Remote Shooting process appears to be unable to write to the folder, thus reporting it as "FULL". If I change to a different directory in DPP4 or EU (it must be a local drive) eveything works fine. Odd that DPP4 can read and write to the folder but the remote shoting window cannot, but you have identified the problem and I can work around it by choosing a local directory. (Running the app as Administrator does not help, just an FYI) THANKS !!!!
12-09-2019 03:12 PM
Well done @CaliforniaDream and glad @Rational1 got past this without having to send it in for a potentially expensive analysis and likely non-repair.
@Rational1 wrote:@CaliforniaDream You, my friend, are a genius! The "FULL" is, in fact, referring to the destination volume. While DPP4 can read, edit and save files in the folder I had selected, when I launch the Remote Shooting app (from DPP4 or EU the Remote Shooting process appears to be unable to write to the folder, thus reporting it as "FULL". If I change to a different directory in DPP4 or EU (it must be a local drive) eveything works fine. Odd that DPP4 can read and write to the folder but the remote shoting window cannot, but you have identified the problem and I can work around it by choosing a local directory. (Running the app as Administrator does not help, just an FYI) THANKS !!!!
12-08-2019 03:08 PM
Yup, I am still confused. Which application are you using? EOSU or DPP4?
You are saying that it using DPP4 in the title. But now you say you are using EOSU.
12-08-2019 03:20 PM
I apologize - I have tried both, with the same result. DPP and EU both use the same shooting window which is where I see the problem. DPP actually launches EU to open the shooting control window, but opening DPP first is not required. Again, the lack of clarity was my fault, but the "FULL" message appears in the shooting control window whether launched from DPP (View>Remote Shooting Window) or from EU (Remote Shooting). It is the same shooting control window, regardless of the method used to launch "Remote Shooting"
12-08-2019 01:16 PM
12-08-2019 02:46 PM
@Rational1 wrote:If I use WiFi to tether my Mark IV to my Windows 10 desktop computer I can successfully open Digital Photo Professional 4 and control the camer, EXCEPT for actually taking a picture. When the shot is composed and ready to take the message window to the left of the on-screen shutter release button has a warning message that states "No more shot [sic] is available." If I press the shutter release on the camera the topp display flashes "FULL" in the upper left corner where white balance is displayed. There is a freshly formatted (in camera) SD card and a freshly formatted (in camera) CF card. If I close out of the EOS utility I can shoot thousands of photos. Any advise on what I am doing wrong that causes the remote shooting window to show "FULL" ???
Now I am confused. Are you trying to use the EOSU or DPP to do Remote Shooting? Each app works independently of the other app.
