4K 23.98P is zoomed in vs FHD 59.94P - EOS M50
Mr_Scary
Wondering if I'm doing something wrong.
EOS M50
When I record a video in (4K 23.98P) the video is zoomed way in compared to (FHD 59.94P)
I feel like maybe 40% magnified if that makes sense. loosing alot of the scene, I need to move way back to get the entire scene.
Or is this normal behavior?
Thanks.
Both pics below were shot at the same distance at 15.
EOS M50 / M15-45 / M55-200 / Vixia HF-M30
6950X / X99 / RTX 2080 XC2 Ultra / Win 10 Pro
3 ACCEPTED SOLUTIONS
Waddizzle
I would guess so.  Use an ultra-wide angle lens if you want to use 4K mode.  I think Full HD is sufficient for 99.99% of the time, and far easier to edit.  If you really need 4K video that much, you should be invested in areal 4K video camera.
rs-eos
Most DSLRs and even some cinema cameras will not read the entire sensor when recording certain resolutions/frame-rates.
If you need a partcular resolution to stay framed the same way (e.g. you have multiple cams; A, B, etc.), you'll want to look into the appropriate equipment.  e.g. cinema cameras that would all use S35 sensors and read out the entire sensor.   Or, full-frame cameras that would all crop the same way.
Otherwise, what Waddizzle points out as a workaround is solid.  You'll have to use wider lenses when you cannot physically back up further from your subjects.
Ricky
Use this reference:
https://www.usa.canon.com/internet/portal/us/home/learn/education/topics/article/2018/July/4K-Video-...
To confirm what Wadizzle and rs-eos "Ricky" has already said.  What you see will be affected by the FOV of the lens since 4K is shot from a cropped portion in the center of the sensor.
5 REPLIES 5
Waddizzle
rs-eos
Ricky
Use this reference:
Mr_Scary
Thank you all, this makes perfect sense.
I'm glad I purchased the camera with the extra zoom lens.
EDIT: Actually what I said above makes no sense, lol..
Just for the record, the new 90D can shoot 4K "cropped" or "uncropped".
