3 x 3 Grid Lines in 5D mk IV viewfinder
JWHoward
I own a 5D mk IV, and recently had the camera in for the offered “Canon Precision Alignment” (or lens calibration). Prior to taking my camera in for this service, I was able to see the 3 x 3 grid lines in the viewfinder … when I got the camera back, grid lines were no longer visible. Easy enough I thought, go into menu, select 3 x 3, and show it. Problem is, the only grid that will show in the viewfinder, is the 6 x 4 … I am positive that the 3 x 3 grid was there before my service, because I used it constantly. I do remember a previous time when I took my camera in, and the exact same thing happened. I called Canon support, and they were able to help me, and the rep said he would put that “fix” into the 5D mk IV help notes. I called this time, and the rep could not help me … but I know it’s possible. I think the previous “fix” had something to do with a  “Reset of custom functions” or “Reset to factory specs” … either way, it’s a bit of work to “experiment”, if it doesn’t work. Also, I’m afraid to ruin my lens calibrations recently completed. Any help or suggestions would be much appreciated.
8 REPLIES 8
Tronhard
Well, I have the 5DIV, firmware version 1.3.3. and it shows the same grid as you now see in the VF.  There is no VF option for a 3x3 grid, just the 5x4 lines. There is for the LCD.
Just to save you the trouble, I did a full reset and there was not change in the grid in the viewfinder, still 5x4.
cheers, TREVOR
Before you ask us, have you looked in the manual or on the Canon Support Site?
"All the beauty of life is made up of light and shadow", Leo Tolstoy;
rs-eos
Are you sure you're speaking about the viewfinder? From page 81 in the User Manual, you only have a show/hide option for the viewfinder's grid and that grid will always be 6 x 4 squares.
Greater control exists for live view where one of the options there is 3 x 3.
Just went through these settings on my 5D IV, and I see no option for putting a 3 x 3 grid in the viewfinder.
Ricky
EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L, 600EX-RT (x6), ST-E3-RT
EOS C70, RF 24-70 f/2.8L IS, EF-EOS R 0.71x
Yes, that is what I found even after a factory reset, but agree that the LCD shows a 3x3 grid - rather odd though... 🤔
cheers, TREVOR
Is it possible that Canon upgraded the firmware on the camera. My 5D Mark IV shipped with firmware 1.3.4 instead of firmware 1.3.3 (current version) I'm surprised that Canon hasn't released firmware 1.3.4 yet.
-Demetrius
EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
EOS 40D & 5D Mark IV
430EX III-RT & 600EX II-RT
-Demetrius
Current Gear: EOS 5D Mark IV, EF Trinity, EF 50mm F/1.8 STM, EF 85mm F/1.8 USM, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D & Sigma 17-50mm F/2.8 EX DC OS HSM
  • When my camera was last in the Service Center, they actually updated to 1.3.4, but had a note that said “not officially released”
OK that makes sense then.
-Demetrius
-Demetrius
I agree with you about pg 81 in the manual … but, I previously owned a Nikon camera, that had the 3 x 3 option available in the viewfinder, and I do remember that when I set the 5D up initially, my desire to get the same grid was accomplished, but was changed when I took it to the Canon Service Center in Costa Mesa, California. It is then, that I contacted Canon Support to ask about it, and the conversation led to the “fix” I mentioned in my initial post. I am currently running 1.3.4 on the 5D
So Canon did upgrade the firmware on your body then. Canon hasn't released firmware version 1.3.4 on their website. I will try on my 5D Mark IV to see if the 3x3 grid can be set in the viewfinder.
-Demetrius
-Demetrius
