01-11-2015 05:14 AM
01-11-2015 10:55 AM
How much dust is it? I ask because it is not possible for the camera to focus on dust in the lens -- it can't actually show up in an image. A build-up of dust would eventually result in a loss of contrast, but not a loss in detail resolving capability.
If it's just a little dust, I'll suggest you do what we tell everyone in the astronomy community: don't touch it! You'll do more damage trying to "clean" it then you it could ever do if you just leave it alone.
If the dust build up is pretty significant... then I might want to clean it out, but for a 500mm f/4L lens... I'd send it off to Canon service for cleaning. There's no way I'd try taking apart a lens that valuable myself unless I was so wealthy that I could afford to treat it like a disposable lens and prepared to buy a replacement lens.
01-12-2015 07:00 PM
Thanks for the advice, i have contacted Canon and they are going to carry out a full service on the lens, and clean the internals thoroughly and reset it to as new condition.
As you say, it's better to spend a few pounds than loose several thousand, appreciate the comments
Regards,
Nick
01-13-2015 09:02 AM
You can certainly turm several thousand dollars worth of lens into a paper weight very quickly.
01-12-2015 01:26 AM
01-12-2015 07:34 AM
@Nickp wrote:
Thanks for the advice and I have arranged for it to be serviced and cleaned by Canon as on reflection you are correct in your comments. It is a precision piece of kit
Yeah, you'd be kicking yourself if you spent several hours cleaning the lens, only to discover that you had screwed up the focus or something and were going to have to send it in anyway. Canon may be expensive, but they do a good job. And if you have a lot of equipment, you can cur your repair costs somewhat by joining CPS.
