10-10-2016 09:00 AM
i have a 1.2 canon 55mm asphirical lens and cant get sharp focus with the adapter on my fuji xe2 or xe1.can you help please?
flurite.thank you in advance.
10-10-2016 10:06 AM
This is a Canon forum but here goes, the adapter screwed up the focal plane. You will probably have to be very close to focus on anything.
10-10-2016 10:08 AM
At f/1.2 your focus will be a very narrow plane. Is there *anything* in focus?
10-10-2016 10:17 AM
I just can't get sharp focus with the cannon lens on the Fuji with adapter
it is not bad but not as sharp as I would expect
10-10-2016 10:19 AM
It is the cannon 1.2 lens! It is not in focus however close I get
10-10-2016 10:29 AM
@FLURITE wrote:It is the cannon 1.2 lens! It is not in focus however close I get
If you are using f/1.2, then you dealing with a VERY narrow Depth-Of-Field. It can get extremely narrow.
http://www.dofmaster.com/doftable.html
You can try to take the lens to a camera shop, and have them test it. I'd bet that the lens is working properly.
10-10-2016 12:38 PM
Not easy in the Highlands!
10-10-2016 10:38 AM
Adapters are for fun, or marketing. It is almost always the case that it will degrade lens performance.
10-10-2016 12:35 PM
Thanks, that is probably it!
10-10-2016 11:48 AM
You might also be having this problem:
https://www.lensrentals.com/blog/2014/06/the-glass-in-the-path-sensor-stacks-and-adapted-lenses/
