12-28-2024
12:58 PM
09:29 AM
Hi! I am brand new to photography and have a canon rebel eos t7. I want to take photos of my newborn and toddler and have been using the nifty fifty. I struggle to take pictures with that lense as I can’t zoom in and out. Any other suggestions on lenses or how to maximize nifty fifty?
12-29-2024 05:22 PM - edited 12-30-2024 08:24 AM
emily, that is also a good lens but as you mentioned, especially when zoomed the background blur (Bokeh effect) will be difficult to achieve but not entirely impossible.
When I offer an opinion on a lens I will normally go with a lens that offers a constant aperture, especially with someone new to photography. It takes some of the uncertainty out of setting your shutter speed and ISO with the aperture being a moving target as you zoom. It also allows you to get those beautiful bohek's and shoot in low light without a flash. Full frame lenses also tend to hold their value better so owning or investing in a full-frame lens can help you scale up your kit without having to replace costly items. They also work exceptionally well on the Canon R bodies with the Canon adapter.
They do cost more which is a challenge. Just keep in in mind your sliding aperture if/when shooting in manual. This may help, it is the aperture max by focal length for the EF-S 18-135 IS USM.
Enjoy the new lens and capturing those memorable images of the little ones.
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
12-29-2024 08:48 PM - edited 12-29-2024 08:52 PM
Ah ok, you need background blur too? The nifty fifty is great at that but as you say,you need a zoom.
There are two ways to get a blurry backgound with lenses: Large aperture lens and/or use long focal lengths.Large aperture zooms may be more expense than you want so going with a longer focal length may be your only option..?
Did you say you've already bought the 18-135? If so try using it at the longer end while set at its largest aperture.Does that give enough blur?
And as you mention it,no dont worry about buying a new camera.It will make no difference for the look you're trying to achieve,which is all about lenses and technique.
Cheers,Ron
12-29-2024 09:53 PM
Demetrius,
Are you thinking/talking about the EF-S 17-55mm f/2.8 IS USM? I was going to add that to my original post but it didn't really extend the range much past her 50mm. Is there an EF-S with a fixed/fast aperture in the EF-S line that has more range?
Personal Gallery
12-29-2024 10:50 PM
Yes the EF-S 17-55mm F/2.8 IS USM lens. I couldn’t remember the exact name. But I was pulled away from the computer and didn’t finish my post. There are no other EF-S zoom lenses with a constant aperture. There are other EF-S lenses with a variable aperture. Such as the EF-S 15-85mm F/3.5-5.6 IS USM lens. Or EF-S 17-85mm F/4-5.6 IS USM lens. Canon did make the variable aperture super zoom EF-S 18-200mm F/3.5-5.6 IS lens. But this lens uses a very slow AF motor. When I mean it’s slow it’s extremely slow to AF. My old EF 70-210mm F/4 lens from 1987 AF faster than that lens. Even though it uses a very old and slow Arc Form Drive AF motor which is also noisy. I’m not even comparing it to the fast Ring Type USM AF motor in use since 1987. Canon never released an STM replacement model. This lens was released with a very slow Micro Motor instead. In the early years of the EF-S Mount. Canon released decent lenses with Ring Type USM AF motors. Later on around 2012 they started to drop the Ring Type USM lenses and Micro Motor lenses. They started replacing them with STM lenses with slower variable apertures instead. The EF-S 17-55mm F/2.8 IS USM lens never got upgraded to an STM version. Or a version II with Ring Type USM. 4 EF-S lenses never got an STM replacement those were the EF-S 60mm F/2.8 Macro USM, EF-S 18-200mm F/3.5-5.6 IS, EF-S 17-85mm F/3.5-5.6 IS USM & EF-S 17-55mm F/2.8 USM lenses. These lenses were simply discontinued with no replacement. Some newer STM replacement lenses sell along with their Ring Type USM counterpart. One example is the EF-S 10-22mm F/3.5-4.5 USM & the EF-S 10-18mm F/4.5-5.6 IS STM lens.
12-30-2024 08:21 AM
That's what I thought, it is a very nice S lens. Canon never really seems to focus on fast lenses in their APS-C line.
Personal Gallery
12-30-2024 08:59 AM
In the early years Canon did try with very nice fast Ring Type USM lenses. But the market wasn’t there for those lenses. Ring Type USM lenses are more costly to manufacture vs STM and Micro Motor.
12-30-2024 11:42 AM - edited 12-30-2024 11:44 AM
"I went with the lense mentioned above (18-135) but the issue is that I am looking for a more blurry background and that one seems to not have the lowest apperture. ... I have thought about upgrading my camera but I just started taking photos ..."
emilykate3 first off stop. Yes stop! Don't buy anything thinking that a new lens or a new camera will fix everything. I can almost guarantee you it won't. Knowing how to use what you have and finding out what limitations it puts on you is paramount.
Let's get some good shots under your belt first. Perhaps not the great shots you seek but some good ones. First go to the Canon web site and d/l DPP4 which is Canon's post editor. It is free. Set your camera to record raw files instead of jpgs. This is the start and is how all great photos are made. For now let's use fixed settings so we have a base point. Use One shot and not any AI-servo or auto focus mode. That's important. Set ISO around 800 for now. Not Auto ISO for now either. No auto anything. Set the camera to P mode. Now try some shots. How old are the kids you are trying to photograph? Outdoors is a plus. Keep in mind if your shutter speed falls too low (indoors) you must hold the camera very steady. Good shooting technique is a must.
Take these photos and u/l to you computer using DPP4. There you can do simple exposure adjustment and color enhancements, crops, etc., whatever. You can make this as simple or as involved as you like. And as you become more familiar with DPP4 you will do some really nice things. Taking photos with the camera is only half of the job. Post editing is the other half. There are lots of simple tutorials on You Tube about DPP4. Here is the Canon USA site Canon USA DPP 4 and where I would start.
Right now ignore any advice to buy any new gear.
01-20-2025 09:57 PM
I love working with my 35mm, 50mm and 24-70mm for newborn sessions. The main focus of my business has been Newborns for the last 10 years so I will drop some pearls of wisdom for you.
1. invest in quality not quantity. Avoid cheap items for Amazon or china shops, they will look cheap and not be worth the cost.
2. invest in a good lighting system
3. go with a mirrorless canon as soon as you have mastered the triangle (ISO, aperture, shutter speed) and are able to correctly light
4. take a workshop or 12, it’s harder than people think to learn as you need to not only be a great photographer, but good with light, understand safety and posing for each pose, working with props, know the kinesiology of safely moving a newborn between poses, and anticipating the newborns needs.
5. good glass (those I mentioned above)
good luck! Keep shooting and practice (with dolls is a great way to learn lighting and angles)
