07-18-2014 01:46 PM
My lenses need some cleaning badly! I'm using the Canon T3i and the 18-55 kit lens, the 55-250, and the 50 F 1.8
07-18-2014 03:12 PM
@willfoxylove wrote:My lenses need some cleaning badly! I'm using the Canon T3i and the 18-55 kit lens, the 55-250, and the 50 F 1.8
What sort of dirty? Hit by a muddy splash of water as you chased after elephants? Or a more pedestrian "fingerprints on my front element" dirty? If the later, you can use a bit of lens cleaning fluid and a lens tissue wipe. Gently blow loose dirt away with a squeeze blower and lightly sweep any stubborn "chunks" with a fine lens brush, usually sold as a combination tool. Repeat as necessary until you are down to lint or grease issues, then use the fluid and wipe.
07-18-2014 04:49 PM
Amazon shows a kit here, http://www.amazon.com/Professional-Cleaning-Cameras-Canon-Pentax/dp/B0080JH3YE/ref=sr_1_3?ie=UTF8&qi...
Maybe buy it at a local photography shop and support those guys. It couldn't be that much more than the online cost.
07-18-2014 03:12 PM
07-18-2014 03:58 PM
Both! But mostly the second :P. So any cleaning kit on Amazon will do?
07-18-2014 04:49 PM
07-19-2014 09:11 AM
The big box stores like Sam's Club and Costco usually have huge boxes of Zeiss lens wipes for crazy cheap. I always keep a small stack in my camera bag.
