Video issue when filming Canon EF 40mm f/2.8 STM
mim23beat
Hello.
When im filming with T4i and Canon EF 40mm f/2.8 STM during motion the picture is not smooth, look at attached footage.
https://www.youtube.com/watch?v=ESzJmqgIO0s
Video of issue
When filming steady shots all good.
Im not talking about shaky video - its normal , im talking about this step by step motion of picture to right.
Thank you for help.
I was on manual focus, so thats not the issue. After multiple tests and deeper investigation:  issue is some sort of Rolling Shutter, you can see similar issue here https://youtu.be/MQCMsdhlXC0?t=1m54s
The solution in my case is downgrade video quality to 720p 60fps.
Thank you
5 REPLIES 5
Waddizzle
I'm not sure if I am seeing what you're seeing.  Do you see this issue when you play back videos in the camera?  On your local computer?  In fact, I don't see anything beyond some camera shake.  Could there be a YouTube connection issue for you?
TTMartin
@mim23beat wrote:
Hello.
Video of issue
Thank you for help.
What you are seeing is typical of the Auto Focus of that camera. Newer and higher end Canon cameras use the Dual Pixel AF sensor, which is much more responsive to changes in the focus distance.
Canon EOS M5 Dual Pixel CMOS AF
Thank you
Thank you
Downgrade the video quality?  That sounds more like a work around, than an actual solution.
But, if you're happy, then I'm happy.
mim23beat
Actually the solution is to increase fps. On t4i the only way to do it go down to 720p.
Thank you
