TS-E24mm F3.5L II – adjustment/service
thomaskyhn
While I have the impression that other people find the TS-E24mm F3.5L II very sharp, mine has never been anywhere near as sharp as my other Canon lenses; on the contrary, it has always appeared a bit blurry to me, and I'm wondering if there could be something wrong with it.
Has anyone else had similar experiences? Assuming this is something that could be fixed by having the lens serviced/adjusted, does anyone have a rough idea how much that would be?
7 REPLIES 7
jrhoffman75
Hi.
Go to this website, register your product and initiate a service request.
Canon Support for TS-E 24mm f/3.5L | Canon U.S.A., Inc.
ebiggs1
I agree with JRH you will only know if you send it in for evaluation. Unless it was subjected to a big impact or fall or was disassembled by inexperience person or persons, I doubt it will be successful but you will never know if you don't send it in. Lenses are pretty much set as soon as they are manufactured.
"does anyone have a rough idea how much that would be?"
Canon probably has a flat rate plus parts but I don't keep current with it. They will give you an estimate before they proceed for an OK. Keep in mind AF problems and OOF or not sharp pictures are almost always user caused. Not equipment.
thomaskyhn
Thanks for your replies.
It was like this from when I bought it (new), and it hasn't been damaged in any way. I should have had it checked a long time ago; so far I've assumed that it was supposed to be like this, but now I want to know if this is really the case. I'll try contacting Canon about it.
Thomas
wq9nsc
Since this is a manual focus only lens, are you focusing through the viewfinder or using live view magnified for focusing?
At times I do miss the split image focusing screen of my old Canon film camera but even when available for your model, they don't play well with other parts of the modern DSLR.  The stock focusing screen setup, at least in my 1DX series bodies, is not wonderful for manual focusing.
Rodger
I always use live view magnified, and always use the lens with the camera (R5) on a tripod. And even in live view, it's like something is off or misaligned.
ebiggs1
Yeah, you need to send it in if for no other reason than your own piece of mind.
Yes, not much else to do. I'll take it to a Canon repair center next week.
Avatar
