RF-S 10-18mm f/4.5-6.3 IS STM Help finding serial number
boreynolds
Enthusiast
CAN ANYONE help me find the serial number on the RF-S 10-18m? I have the box but there's multiple numbers on it and ZERO numbers on the lens except the obvious H E L P!
10 REPLIES 10
Tronhard
VIP
VIP
The serial number can be found on the barrel, but very close to the lens mount face - it is located about 4cm (1.5") to the right of where the letters 0.14m /0.46ft are printed.  Since the area around the serial number is dark grey or black plastic and the numbers are tiny, but not painted in white, you have to rotate the lens under light to get the number to display.
How to find the serial number on a Canon Lens (custhelp.com)
If you have a receipt from a store, that should have the serial number listed as well. Always keep a copy of your receipt along with the box, packing etc. for storage and if you sell the lens later it can get you a better price
cheers, TREVOR
kvbarkley
VIP
VIP
Thanks for that!
Since it was way down the page I grabbed a screen shot of it:
cheers, TREVOR
I do have the box but there's a ton of numbers on it and for the receipt. I bout it on Amazon. Great info tho? Thank you!
I don't get it. The picture doesn't show the serial.
You should still have a receipt from Amazon, usually you need to go to your account to get that if it was not sent to you.  I posted the photo of the image showing the serial number after checking KV's post, if you missed that or still don't see the serial number I have reposted it here with the number circled in red.  You should be able to also match that with a number sequence on your lens box.
cheers, TREVOR
The little numbers on the lower right engraved into the lens.
Snap! {:-)
cheers, TREVOR
Sorry, did not see your reply.
BTW, if this comes up again, Ken Rockwell always puts in a picture of the serial number when he reviews a lens.
